what crank pulley to use on a zetec turbo?
28-11-2007, 09:35 PM
got a phone call earlier from the company balancing my bottom end, they said they need the crank pulley? my mate has said i dont use the 2.0 mondeo one in a zetec turbo? any ideas? cheers
28-11-2007, 10:15 PM
Engine Machinist
if its going in an erst or frst, surely you can use the single 'v' cvh one and use your original alternator?
28-11-2007, 10:41 PM
Team HOTHOT!
depends on the alternater , or if u need a cps crank pully side? is so then a 1800cvh one if not a zetec one or if ur gona use all cvh shit like alternater then a cvh one , its just so its all ballaced to each other
28-11-2007, 11:02 PM
Cant use a CVH one as the Zetec water pump runs off the same V groove pulley which you need off a 1.8 Escort or Fiesta Zetec (The mondeo pulleys are different)
You need a 1.8 Zetec pulley mate, iam sure, though ill check anyways.
28-11-2007, 11:10 PM
yam yammer
Ive got a cvh one on mine which is running standard mfi managment
28-11-2007, 11:15 PM
Quote:
Guessing you have a ZVH not a full on Zetec?
28-11-2007, 11:20 PM
Audio specialist
i use a 2.0 zetec one.... but then my engine is the other way in the bay LOL
29-11-2007, 05:59 AM
Just use a Zetec one unless you fit a electrical water pump then it does away with one more pulley then you can use the cvh set up if you wish
29-11-2007, 08:11 AM
Lukesville
1800 zetec pulley from any escort or fiesta
29-11-2007, 10:37 AM
yam yammer
yes mate its just a zvh
29-11-2007, 11:32 PM
breakers for me on sat, cvh or 1800 zetec then? lol
30-11-2007, 10:17 PM
CVh if your running a ZVH or electric water pump.
1800 Zetec if you want the right one
02-12-2007, 02:05 PM
ive got a black v belt pulley i found in the garage which i believe to be an 1800 zetec? which i have given them to balance
02-12-2007, 03:59 PM
hi mate .i use a 2ltr zetec one my fiesta with no problems at all
02-12-2007, 04:00 PM
i take it you used a zetec alternator etc?
02-12-2007, 04:15 PM
Quote:
No just use the pulley from the zetec and fit it to your RST alternator
robnock
21
13-05-2019 05:29 PM
Chopshop85
17-08-2015 06:38 PM
JoeyBoyden
14
15-08-2015 09:51 PM
turbobill
09-08-2015 05:21 PM
turbobill
01-08-2015 08:55 PM
