4x4 Q ...
i have only had my 4x4 not evena week and the fooker shit itself... clutch cable seems fine, but no resistance on pedal... and wont go into gear.... but if you put it in gear and start it up it , and change with no clutch its fine... Release bearing or clutch ratchet/cable??
btw mt75 and 2.0 dohc 4x4 sierra>!
ya know what i mean though
if itsb the bearing the pedal will feel normal. if the ratchet ya will feel its smooth
with a paddle clurch irs wasyer as the pedals a coont and would feel fether light like a hydrolic clutch
Len, if the cable snapped the pedal would not travel back to the original point and stay at the floor... This has happened to me a few times
Taking the box out of a 4x4 aint too difficult. Took me and me bro an afternoon to do without rushing andour first time @ touching a 4x4. Will let ya know bout putting it back in
right... just tryed the clutch pedal thing.... no matter how hard i try i cant get a ' click'.... and looked under the dash at the quadrant on the pedal, and it moves with the pedal. what else could it be????
"there was a slight metallic noise... nothing major"
That narrows it down
I think you may of snapped the teeth thingys off the clutch at a guess... Rip the box out mate, only way to be sure
Sometimes heavy duty clutches can confuse the fook out of the clutch ratchet mechanism! Get under the car and have someone push the clutch to the ground if the mechanism isn't moving sufficienly to disengage the clutch then you will have to try adjusting it manually by placing a bar behind the clutch fork when it is half way across to stop it from moving and then release the pedal and it should click several times on the ratchet! This should work if there is nothing broken inside the box/clutch!
If you don't understand what i mean bell me tommorow as its easier to explain on the blower
I would follow Spadges advice first as ratchet problems can occur quite often,id be very suprised if it was anything major as ive never had a minutes trouble with the car since i fitted the new clutch.If you do have to take the box out and you can get access to a ramp your looking at about 3-4 hours work not particularly hard,i changed the sump when i took it off and took all the steering gear off and the engine out and drove home in it that night.
I feel gutted matey,sorry youve had the bother i hope its easy to fix.Anyone who knows me, knows how fussy i was with the car fingers crossed.Some of the trim parts were supplied by Mr Spadge though he wouldnt know that as i bought them under my e/bay id.
best hope it's not the ratchest
i'd rather do a clutch change
the other way to do it is to push the pedal all the way and then side step your foot and let it bang up into place again, but if you've pulled the pedal all the way to the foor and it's not clicked then it might be easier to buy a new clutch cable incase it's been stretched rather than do the box or the ratchet mechanism in the pedal box
Originally Posted by SPADGE
Any joy Lennie?
