Will a 1600 Zetec fit in an XR2i (H reg).
Old Nov 10, 2007 | 04:47 AM
walk04's Avatar
walk04
Default Will a 1600 Zetec fit in an XR2i (H reg).
I would like to fit a 1600 Zetec enigine from a Focus into my XR2i rally car. It would be easier for me if I could still use the present standard gearbox, is that possible?
If I have to fit the Zetec gearbox, will the driveshafts from the standard gearbox fit?
Old Nov 10, 2007 | 05:18 AM
wirralphil's Avatar
wirralphil
Default Re: Will a 1600 Zetec fit in an XR2i (H reg).
so you want to fit the Zetec SE engine with the front mounting inlet instead of the rear mounted inlet off the escort 1600's?
what age is the Xr2i as none of them came with a crossflow?
Old Nov 10, 2007 | 06:27 AM
B19LRW's Avatar
B19LRW
Its Broken.....
the answer is NO, well not a bolt in job. just buy a donor 1800 2i and put its all in the 1600. cheaper too!!
Old Nov 10, 2007 | 07:06 PM
walk04's Avatar
walk04
Sorry, my mistake, the car is an H reg XR2i which has had the injection removed and replaced by Webber 35's. It's not a crossflow....
I have been given an engine but I don't want to go to an 1800 because that would put me in the 2 litre class. Better to stay with a 1600. The present engine runs out of breath at about 100mph and would cost too much to get more bhp out of it.
Old Nov 10, 2007 | 07:10 PM
RichieST's Avatar
RichieST
focus 1.4/1.6 have inlet at front, exhaust at rear. costly job to get it in and running i'd have thought!
Old Nov 11, 2007 | 05:52 AM
Wardy257's Avatar
Wardy257
Just use the 1.6 ZETEC E from a Fiesta Si. It is not the best version of the eingine but on twin 40s will give 125 bhp.
Old Nov 11, 2007 | 02:59 PM
Oranoco's Avatar
Oranoco
Will it though? The Fiesta Si 1600 Zetec is about as much use as a boat anchor
Old Nov 11, 2007 | 06:53 PM
XR2's Avatar
XR2
Zetec-E (Fiesta MK3 and Escort 90-) will bolt straight in.
The Zetec-SE (Fiesta Sport, Focus) has got more potential on standard spec. When the 1600 is used for racing it will be tuned!? So do something to the E and it will work well...
Old Nov 12, 2007 | 03:31 PM
Wardy257's Avatar
Wardy257
There is no doubt the 1.6 ZETEC SE is better than the 1.6 ZETEC E. However the ZETEC E will be easier to fit. The 1.6 ZETEC E will give you 125 bhp with twin 40s or TBs with aftermarket management. More bhp is possible but at huge cost.
Old Nov 16, 2007 | 04:49 PM
zippyobrien's Avatar
zippyobrien
better staying with a 1600 cvh than a wanky 1.6 zetec e lump,
with there tiny valves there useless, unless you want to spend lots on gettign a big valve head,
i still reckon more power is possible from a 1600cvh
JoeyBoyden
Jan 4, 2024 02:36 PM
Porplus12
Sep 10, 2015 07:20 PM
gingerturbo
Aug 18, 2015 07:58 PM
track.focus'd
Aug 12, 2015 05:53 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
