Pinto question.....
Old Nov 7, 2007 | 07:49 PM
peteh's Avatar
peteh
Default Pinto question.....
2.0 pinto's found in mk2 2000's are the same block as in the cosworth yeah, just hand picked from the bunch so they are the best one?
so could you use a cosworth 205 block to build a pinto engine, just running big carbs ect etc?
would a 205 with a 25mm over bore be ok?
Old Nov 7, 2007 | 07:54 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default Re: Pinto question.....
Yup, can use cosworth block as well as crank and rods if you liked with a pinto head.
25mm overbore is a bad big tho
Old Nov 7, 2007 | 07:58 PM
peteh's Avatar
peteh
bad big?? could you explain stavros
hear the 1.6 diesel urods are the ones to use as they are strongest
Old Nov 7, 2007 | 08:07 PM
Mark V8's Avatar
Mark V8
0.25mm would be OK
25mm is almost an inch and might cause a few leaks.
I remember reading about using diesel rods in CCC and it is a whole load of hassel compared to bolting in some cossie ones, if you use the cossie crank you will need to use the cossie flywheel and RWD MT75/T5 or use a custom flywheel.
Mark
Old Nov 7, 2007 | 08:24 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
Nope ! - A "correct" MKII RS2000 uses a 20 designated block
Cosworth are designated 205 or 200
Yep ! But carbs choice is ruled by the spec of engine being built
I run an 8v Pinto based on a 200 block running 94mm Accralite pistons
94mm is maximum size Pinto piston I found available
25mm overbore must be a typo !
Old Nov 7, 2007 | 08:25 PM
The Youth.'s Avatar
The Youth.
my pinto was a normal non 205 block with cosworth crank, rods, pistons and flywheel (machined to pinto dimensions) this was running a .5 overbore and ran 181 bhp with dellorto 48 carbs. and a burton stg 3 head with a emerald stg 4 cam
I say was as most of you will know in 2005 the head of no4 inlet valve decided to fall off!!
the carnage that was left included a cracked block. I've got a mint 205 block but still need a .5 oversize piston to start the rebuild.
pics of the damage
steve
Old Nov 7, 2007 | 08:26 PM
RS2000CUSTOM
Details of my engine build here
https://passionford.com/forum/viewto...asc&highlight=
Old Nov 8, 2007 | 07:51 AM
peteh's Avatar
peteh
oh god really sorry , meant 0.25mm over bore
Old Nov 8, 2007 | 08:04 AM
RS2000CUSTOM
Dont worry we know what you meant
90.80mm is standard bore for a 2.0 ltr Pinto
Rebore upto +1.0mm is normal limit
As mentioned though I use 94mm pistons (+3.2mm) on a 200 block with no problems
Using standard stroke crank and standard length con-rods my engine size is 2135cc
chowfornow
14
Jan 5, 2019 09:01 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
20/20 vision
Sep 29, 2015 11:27 AM
chowfornow
Sep 19, 2015 10:47 PM
steff19
Escort Range
Sep 9, 2015 10:14 PM
