no spark S1
Old Nov 2, 2007 | 04:44 PM
scottrs's Avatar
scottrs
Default no spark S1
as some of u know i hav done a full resto on my s1 most of the car is back together and i hav been trying to get it to start things r not going well ,still cant get it to spark been through it a hundred timmes now and its starting to great me down feel that i am so close yet so far away to get this turd to spark
i will go through it again to see if anyone can help , this is what i do have working i can hear the fuel pump priming,the large silver relay under the dash clicks when u turn it over so is prob working ok,,the yellow relay beside the heater under the bonnet clicks when the ignition turns on so again it seems to be working ,the two green wires one from the silver ECU and the other from the insterment cluster ie the ingnition light both have 12 volt supply
now the dizzy looks as near new as u can get when i bought it i was told it was just reconed and the black plastic plug and wires r in prefect condition ,now on the platic bit it has the markins + 0 - , when i test these when the plug is disconected from the dizzy i get 12v out all three with the ingnition on ,is this right i would of thought one would be a +12v an earth and a single wire ......or am i just talkin
please guys really lookin for some help here its doing my head in ,an idiots guide on what to do and check ,wiring diagrams anything i am desperate my mates r pulling the now saying it will never move again lol any help would be great
scottrs1
Old Nov 2, 2007 | 08:46 PM
Barry R's Avatar
Barry R
sounds like the same prob i had
it turned out to be the the small earth wire that connects
near the wiper motor wasnt screwed down
Old Nov 3, 2007 | 04:01 PM
scottrs's Avatar
scottrs
i wsh that was it check that and its getting a good earth ,anyone else got any ideas
if any one has a escort turbo and a muti-meter could u take the black plug of the dizzy and check each wire on the 3 pronged plug on the wiring loom side(not on the dizzy its self )and tell what volts if any u r getting so i can compare with mine
Old Nov 3, 2007 | 06:11 PM
SafeChav's Avatar
SafeChav
You have 12v on the green wires??
Old Nov 3, 2007 | 06:42 PM
scottrs's Avatar
scottrs
yeh the two going to the coil .....................what u trying to say
Old Nov 3, 2007 | 06:44 PM
SafeChav's Avatar
SafeChav
that doesn't sound right
Old Nov 3, 2007 | 06:52 PM
scottrs's Avatar
scottrs
why not ,these supply the coil with the 12volt feed that the coil needs to work ,one green from the insterment cluster when ignition turns on and the other from silver ECU ,what makes u think this aint right
Old Nov 3, 2007 | 06:54 PM
Barry R's Avatar
Barry R
mate dont question safe chav he knows what hes on about
Old Nov 3, 2007 | 07:31 PM
scottrs's Avatar
scottrs
who knows then
Old Nov 3, 2007 | 08:07 PM
SafeChav's Avatar
SafeChav
because i know it like GOSPEL that the black wire is the 12v feed............
Old Nov 3, 2007 | 08:14 PM
scottrs's Avatar
scottrs
right in all honesty r u pulling the piss , if thats true how the hell am i getting 12v on the green ones
Old Nov 3, 2007 | 08:18 PM
SafeChav's Avatar
SafeChav
thats straight up, all black wires in a Mk3/4 escorts are un-fused ignition feeds.
What are you connecting your meter between?
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
