transit duratorq 51 plate
Old Oct 2, 2007 | 03:54 PM
davecosworth's Avatar
davecosworth
IM BACK
Default transit duratorq 51 plate
i need the timing chain settings t(timing marks) as i have had to renew the chain tensioner and the chains
Old Oct 2, 2007 | 04:04 PM
davecosworth
IM BACK
ment to say it was a 2005 engine
Old Oct 3, 2007 | 08:10 AM
Spanthefestaman's Avatar
Spanthefestaman
Mate they are a nightmare i know that much! Ford send new engines to dealers that are timed up wrong to start with! I think they are pinned.
Old Oct 3, 2007 | 05:25 PM
davecosworth
IM BACK
yeh already seen were they pin them i have pinned them up but didnt do the bottom as i was using the tool on another van, the problem i have is that some one in the work shop has moved the bottom pulley whilst we have been waiting for the new chain and tensioner and guides so now the bootm is out i have check the ford tsb manual and it say 50 degrees btdc but how do i find this out with out renmoving the head
Old Oct 4, 2007 | 08:17 PM
Spanthefestaman
hum, does the chain not have coloured links that represent where the timing marks are. Quite often as a rule if the crank pulley has a keyway then that is straight up when at TDC. Thats a bit of a do dah you are in. Perhaps you could take an injector out and but a rod down the hole and see where tdc is using that and then set it with a protractor ( you laugh ive seen it done and the engine ran well) but would only work if its direct injection, i.e doesnt go into a combustion chamber.
Old Oct 5, 2007 | 07:29 AM
davecosworth
IM BACK
yeh i have aligned the coloured links on the chain but they only do the cam pulleys and the deisel pump not the bottom pulley, i did think about doing that with a a rod, there is no pin on the bottom pulley either its is a pain in the arse
Old Oct 5, 2007 | 06:13 PM
MrMPuk's Avatar
MrMPuk
Have you tried the other end of the crank? I know this is where the timing pin goes on the 2.5Di.
Old Oct 5, 2007 | 06:55 PM
Spanthefestaman
thats it then, im out of ideas. Another thing to try is win one of those manuals off ebay apparently there quite good. ive ordered one today £4 bargin.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
bobsworth
77
Mar 24, 2016 09:30 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
Iain Mac
Sep 30, 2015 09:39 PM
