brake servo vaccuum pipe
Old Sep 8, 2007 | 09:07 AM
Chris69's Avatar
Chris69
Default brake servo vaccuum pipe
mine has started popping out and i'm only running 5psi at the mo
is there a way of securing it better??
shat me pants when it went off boost abruptly yesterday
Old Sep 9, 2007 | 11:49 AM
Šhatter Box's Avatar
Šhatter Box
yes you can go to ford and get a new ring seal kit for the inlet side
Old Sep 9, 2007 | 02:53 PM
jayRS's Avatar
jayRS
as above, new seals are the best bet
Old Sep 9, 2007 | 09:00 PM
Chris69's Avatar
Chris69
great stuff guys thanks alot i'll go down and get myself a kit
Old Sep 10, 2007 | 10:39 AM
KEVFRST's Avatar
KEVFRST
bit of off topic but is the ERST Servo same as FRST?
Old Sep 10, 2007 | 04:52 PM
jayRS's Avatar
jayRS
i belive so mate
Old Sep 10, 2007 | 07:05 PM
Chris69's Avatar
Chris69
the servo is the same mate- jus need a differnt vaccum pipe to connect up the respective inlet
Old Sep 11, 2007 | 02:56 PM
Neil@FastFord's Avatar
Neil@FastFord
Jano at Oddkidd Creations can modify the inlet so it takes Festo fastenings.
Very cool and perfect seal. I will be doing this at some point
Old Sep 11, 2007 | 10:12 PM
Šhatter Box
no there both diff
Old Sep 12, 2007 | 08:14 AM
Chris69's Avatar
Chris69
wots festo fastenings mate? some sort od screw type fastener?
Old Sep 12, 2007 | 08:20 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Copy paste off my site..
The components below allow the use of all the vacum and airlines from the inlet manifold to be able to use one connection from the manifold.
I.e
Map Sensor
Fuel Regulator
Boost gauge
Master cylinder
+ anything else you would like or need to use.
It works like this:-
The large boss you can see is what i supply for ?6. This allows a Cosworth ACT sensor (Air Charge Temp) to screw into it and then be screwed into the factory fitted place on the CVH EFi inlet manifold. NO DRILLING or NEW THREAD etc..
The same boss allows the 8mm pipe line connector to screw into it, but will need taping into the manifold (See pic below)
The 8mm line is then connected to the splitter.
The splitter has 3x 6mm line outputs (More or less available) used for the listed items above.
You can design any type of extra gauges or bends etc. please ask.
The other 8mm line out the oposit side of the input from the manifold, leads to the vacum master cylinder via the one way valve.
The pipeline is designed for another use which uses 100psi+ so it has no problems with our boost pressure
Old Sep 12, 2007 | 10:20 AM
Neil@FastFord
Nice one Jano
Old Sep 12, 2007 | 11:12 AM
Versus_Creations
Ask me a question!
No probs Neil, another nice little mod to clean up the pipework and make it safe without having silly seals poping off or pipes leaking etc..
There are many other uses for this type of setup please aks for any more info etc..
Regards
Jano
Old Sep 12, 2007 | 08:43 PM
frsjon's Avatar
frsjon
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
