ofab or ofac
Old 13-08-2007, 02:20 PM
grayfezzie
grayfezzie's Avatar
Default ofab or ofac
which one is better?
regards gray
Old 14-08-2007, 05:00 PM
crazycage
crazycage's Avatar
Default Re: ofab or ofac
regards gray
ofab
Old 14-08-2007, 05:48 PM
Moondust_crust
Moondust_crust's Avatar
why?
Old 15-08-2007, 08:23 AM
jrs
jrs's Avatar
As it it's easyer to up the boost
Old 15-08-2007, 04:47 PM
frsjon
frsjon's Avatar
think of a escort cossie's...big turbo and small turbo....you'd have the big turbo every time ...that the difference between ofab and ofac...ofab came first,ofac was ford being tight and sensible
Old 15-08-2007, 07:03 PM
jrs
jrs's Avatar
What's your's on jon?
Old 15-08-2007, 07:47 PM
frsjon
frsjon's Avatar
ofac
Old 15-08-2007, 07:48 PM
frsjon
frsjon's Avatar
ofac didnt know the difference when i bought it ..but i so wish it was ofab
Old 15-08-2007, 08:54 PM
jrs
jrs's Avatar
mine was so i converted it
Old 16-08-2007, 08:10 PM
frsjon
frsjon's Avatar
cool...something to think about...did have all the ofab parts but sold them to a mate to convert his s2 to efi
Old 17-08-2007, 12:57 PM
sailorbob
sailorbob's Avatar
The OFAC ecu is actually the better ecu from what I've managed to deduce. The boost limit only becomes an issue for OFAC when going for boost higher than the 2.5 bar absolute the sensor can handle (and this is only a problem because most tuners don't know how to alter the OFAC code to suit a higher reading map sensor).
EDIT added text 'absolute the sensor can handle'
Old 17-08-2007, 05:03 PM
jrs
jrs's Avatar
Originally Posted by sailorbob
The OFAC ecu is actually the better ecu from what I've managed to deduce. The boost limit only becomes an issue for OFAC when going for boost higher than 2.5 bar (and this is only a problem because most tuners don't know how to alter the OFAC code to suit a higher reading map sensor).
It's not easy to get it over 1 bar of boost that's why most only go to 15psi
Old 26-08-2007, 02:20 PM
fizzyturbo
fizzyturbo's Avatar
sounds like the age old debate again......
Old 27-08-2007, 08:38 AM
Oranoco
Oranoco's Avatar
15psi is over 1 bar though as 1 bar is 14.5psi
Pretty sure MSD's Stu said it was a software issue rather than a hardware issue and they had cracked it.
Old 14-09-2007, 10:31 AM
<____ALEX____>
<____ALEX____>'s Avatar
can anyone tell me what ecu this willl be??? FOAF-14A59-AA ????
will it be ok for a fiesta rst engine?
Dahl88
22-08-2015 08:16 PM
Jasesapphy
20-12-2004 04:24 PM
escort1989uk
23-11-2004 09:41 PM
Dilithium
11-11-2004 05:26 PM
Quick Reply: ofab or ofac
