Puma 1.7 - need workshop manual and timing gear?
Old Sep 6, 2007 | 03:41 PM
bobfish's Avatar
bobfish
Default Puma 1.7 - need workshop manual and timing gear?
Guys,
I've gotta do a timing belt change on a 1.7 puma this weekend. Actually i started it last weekend but put the thing back together as i couldnt see any timing marks?
I've been told i need a locking pin thing that goes in the crank, i know this is only my first post so people will be a bit apprehensive to help me (even more so because i'm a jap car fan ) but i wanted to ask you guys
a) Does anyone have the engine workshop manual? i cant find one, and i want to know where this hole is that i have to insert the locking pin through to time the engine up
b) does anyone have one of these locking pin kits that i can either borrow (in exchange for some beer tokens of course) or could you measure it up so i could make my own?
Or if anyone can describe where the hole is i need to put the locking pin in then sweet, go ahead.
Thanks very much guys
Carl
Old Sep 11, 2007 | 02:28 PM
bobfish's Avatar
bobfish
Noone even have a link to some workshop manuals or anything?
please?!
Old Sep 11, 2007 | 09:25 PM
BRI308's Avatar
BRI308
Default timing belt
i did my first one last week ,are you a reasonable mechanic? it took me about 3 and a half hours and that what i do for a living ,the hole for the pin is behind the driveshaft o/s 10 mm or 12 mm bolt head,the flat bar that locks you cams together isnt special ,have you a good motor factors near you ? we bought our kit for £15,think its a sealy item,i think if you go on autodata you can download timing belt data ,give your self plenty of time
Old Sep 12, 2007 | 08:16 AM
bobfish's Avatar
bobfish
Well i've rebuilt two RX7 engines, a couple of cossies and lots of other stuff too so i'd say im pretty reasonable Although on my first cossie i did put a coolant line into an oil line and filled the sump with coolant haha.
I looked behind the driveshaft someone else told me it was around there but i couldnt see it...hmmm. Guess i just need to look harder!
Ive got a good motor factors near me yes, do you remember the part number for the kit?
I dont suppose you could post it to me could you and i'll paypal you some money as a deposit on it?
I dont have autodata, thats an application isnt it?
thanks for the help dude!
Old Sep 13, 2007 | 03:29 PM
bobfish's Avatar
bobfish
bumpity bump!
Old Sep 14, 2007 | 05:18 PM
JesseT's Avatar
JesseT
Tell me when you have saved it so I can remove it.
Old Sep 14, 2007 | 05:40 PM
Aaroncast's Avatar
Aaroncast
Well i've rebuilt two RX7 engines, a couple of cossies and lots of other stuff too so i'd say im pretty reasonable,
YOUR THE ONLY ONE WHO THINS SO IF YOU CANNOT LOCK A CRANK UP!!!!!!
Old Sep 15, 2007 | 11:57 AM
bobfish's Avatar
bobfish
Thanks for the input
I got halfway through the job and couldnt see any timing marks on the pulleys, so i stopped as the job had to be done that day (persons only car)
You can come help me if you like since your such an expert?
bobfish's Avatar
bobfish
http://www.kolumbus.fi/ulpu.tuominen/Puma_1_7_belt.pdf
Thanks for that mate, got it.
KW-rscos
11
Aug 31, 2015 01:51 PM
Ben26
Aug 27, 2015 08:56 PM
Ben26
Aug 11, 2015 04:19 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
Old ford
Jul 31, 2015 06:50 AM
