typical - escort problem - help needed FAST
Old Jul 14, 2007 | 11:12 AM
bluescortcossie's Avatar
bluescortcossie
Default typical - escort problem - help needed FAST
i have someone coming to look at the escort GTI that i am selling and now the temp gauge has decided to read in the red all the time , the engine is stone cold but the gauge is shooting up as soon as the ignition is put on , i have tried disconnecting the sender and its still doing it so its earthing somewhere
any ideas where the cables run ???
Old Jul 14, 2007 | 11:21 AM
dojj's Avatar
dojj
Resident Wrestling Legend
it'll run to the back of the dash, but that's not really helping is it
ignition on, wiggle some wires in the engine bay and go from there
alternativly you can always look for the engine loom mulitplug and disconnect it to see if this stops the problem, thus eliminating loads of hard work
Old Jul 14, 2007 | 11:43 AM
bluescortcossie
found that it is the sender at fault , but have no time to get another !!
anyone know what the other plug does on the thermostat housing ?
Old Jul 14, 2007 | 11:53 AM
RichieST's Avatar
RichieST
i'm pretty suree one temp sensor goes to the gauge, and the other is a temp sensor that goes to the ecu. It does sound like you need the sender replacing. Scrapyard? They should be the same on any zetec engined ford??
Old Jul 14, 2007 | 11:56 AM
dojj's Avatar
dojj
there will be a clour code on the sender, make sure the replacement is the same
Old Jul 14, 2007 | 12:29 PM
bluescortcossie
trouble is the bloke who is intersted in buying it will be here in 1 hour and the nearest place i can get one from is over an hour away !
Old Jul 14, 2007 | 01:59 PM
dojj's Avatar
dojj
tell him the problem and say you'll get it sorted
Old Jul 14, 2007 | 04:37 PM
bluescortcossie
car is now sold
he was a bit concerned about it but never mind
Billy_RS
16
Oct 11, 2025 09:41 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
TommysKeeper
13
Aug 14, 2015 08:22 PM
col93saphcos
Aug 7, 2015 03:21 PM
