using a fwd gearbox in a mid engined car??
Old Jul 13, 2007 | 10:08 PM
tracktoy's Avatar
tracktoy
Default using a fwd gearbox in a mid engined car??
had a bit of a thought for a project car
what would be the pros and cons of turning a front wheel drive transverse gearbox through 90deg- running two driveshafts from the drive flanges to a front and rear diff?
Old Jul 13, 2007 | 10:31 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
well a transfer box reduces the power to the front by a set ratio.....sending 1/2 the power to the front would probably make it drive funny...
Also if its open diff fwd gearbox then it'd be horrible if any of the 4 wheels broke traction...if it was a lsd box it'd also drive funny when traction btoke as the diff would lock possibly putting extra stress on things.
Thridly theyre normally weak when only driving 2 wheels the way they should..
I'm not sure if its a good idea really myself...if it was a simple setup i'd have seen one already
Hope that helped a bit and not just thrown spanners in the works..
Dan
Old Jul 13, 2007 | 10:35 PM
SillyFezzaMk1
Rubber Rhino Crew
I know.......use a mid engined 4x4 cossie lump...with a short prop to rear and a looooong prop to the front (obviously you'd need to use a 2wd sump for prop clearance......
Front diff would have to be bespoke i'm affrad or you could modify a 4wd sump and diff to run up front....(they're designed for oil to be in the sump though I think so might pose probs doing it this way.
Dan
Old Jul 13, 2007 | 10:40 PM
tracktoy's Avatar
tracktoy
its just ideas at the moment
my thought was to use an atb diff in the box- should send most of the power to the rear if there is any traction loss as it would most likely be the front- use an lsd for the rear diff and open front
i know ther are physically weaker than rwd/4wd boxes but there are some hight powered fwd cars about these days
was thinking it was too simple to work myself
Old Jul 13, 2007 | 10:43 PM
tracktoy's Avatar
tracktoy
Dan
thought of that too but the layout would be very long at the back ie engine then box then diff
front is less of a problem as you could use a rear diff turned upside down at the front
Old Jul 13, 2007 | 11:01 PM
SillyFezzaMk1
Rubber Rhino Crew
no easy solution really....trouble is you cant really create a decent driving car with just normal diffs if its 4x4... you need a transfer box to split the power as you dont really want a 50/50 power split (which you would get with out a transfer box.
I know the cossie 4x4 setup is long but you thought about having the engine instead of a passenger seat?
Dan
Old Jul 13, 2007 | 11:07 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
the prop might have to be at a big angle, or the engine may have to be on one side of the car... alternatively, you could have the diffs over one side.
also, think about the fianl drive/ diff ratio's... you'd have lets say a 4.1:1, plus whatever the diff ratios would be.
lots to think about
Old Jul 14, 2007 | 06:30 PM
tracktoy's Avatar
tracktoy
the other option was to have a something like 2wd inline engine and box turned through 180deg and placed in the middle of the car so that the gear box would be in the trans tunnel- then fit in a transfer box to send power to front and rear
problem here would be to find a transfer box that could do this
Old Jul 14, 2007 | 07:44 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
PMSL
Mate, if you turn it through 180 degrees you will have 6 reverse gears and 1 forward
Old Jul 14, 2007 | 07:54 PM
tracktoy's Avatar
tracktoy
Originally Posted by Chip-3Door
PMSL
handy for parking
Old Jul 14, 2007 | 08:07 PM
Chip's Avatar
Chip
I wanted to do this using a calibra turbo gearbox and transfer box, turned 180 degrees so i have 6 reverse gears but then run an H22a honda engine that runs the other way around, but I was reliabley informed the helicals wouldnt like being spun backwards
Shame cause it would have been a doddle to do in my car and the gearbox is ideal cause it would end up rwd/4wd electronically selectable and also only normally transfer power to the front to pull out of a bend once the rear had started to slip.
ah well
Old Jul 14, 2007 | 08:12 PM
tracktoy's Avatar
tracktoy
ah well
but i was thinking of using 2x 2wd rear diffs, these could be turned upside down if need be to drive the corect way (still run in the same direction but will drive in opposite direction)
Old Jul 15, 2007 | 01:54 AM
Chip's Avatar
Chip
i dont think you have though much about how the rear diff would fit into the fwd casing
Old Jul 15, 2007 | 06:12 AM
tracktoy's Avatar
tracktoy
why would it need to go into a fwd casing
Old Jul 15, 2007 | 07:55 AM
fordpop's Avatar
fordpop
as long as the engine\box you are turning 90 degrees has a LSD in it, it would work in theory, as long as the diffs were the same ratio
Old Jul 15, 2007 | 03:10 PM
tracktoy's Avatar
tracktoy
well thats what i was thinking- the strength of the box is the only major issue as far as i can see
JoeyBoyden
Jan 4, 2024 02:36 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
knight19770
Aug 4, 2015 12:36 PM
