zvh engine ANYONE ? update 06/10/07 after rolling road
Old Jul 12, 2007 | 07:13 PM
drsrst2zvh's Avatar
drsrst2zvh
Default zvh engine ANYONE ? update 06/10/07 after rolling road
Basically after some info, my series 2 has a 2ltr zvh engine in which i built usuing standard zetec pistons and a 1.5mm de-comp plate its set at just under a bar of boost and a reasonable bit of advance on the dizzy(think i need and adjustable pulley to get it spot on) and it goes spot on pulls nice all the way through the revs, but we built one for a friend of mine but instead of using a de-comp plate he skimmed the standard zetec pistons by 1mm and when we try adjusting his boost and timing it just pinks is this because the compression is still to high as the rest is set the same as mine ?
Old Jul 12, 2007 | 11:26 PM
MarkXr's Avatar
MarkXr
Strange, I have the pistons skimmed 0,7mm. and running 0,9 Bar boost.
No troubles with detonation......
In my opinion it must be for an other reason. Maybe way to less fuel under full load.
Old Jul 12, 2007 | 11:31 PM
Fiecos Dan's Avatar
Fiecos Dan
Dee comp plate isn't a good way to go, piston machining is better when done correctly.
As for your mates dettin, Its all down to the chip/ecu's, and set up, and not the engine (even tho its not unheard of on different engine designs)
Old Jul 12, 2007 | 11:47 PM
MarkXr's Avatar
MarkXr
Didn't know a decomp plate isn't a good option.
Anyone has experience on what's the max boost with 0,7mm. skimmed pistons? (sorry to steal the topic)
drsrst2zvh probably a decent setup will sort the problem out.
Old Jul 13, 2007 | 05:41 AM
drsrst2zvh's Avatar
drsrst2zvh
but you can get it to pink even low down so this is what makes me think the compreesion is wrong i mean although ive had 1mm off the pistons i dont know how much the block or head have been skimmed in there lives so if those two have had a mm off between them im running standard comp because the piston amount is just replacing what has been removed from the block and head ?
Old Jul 13, 2007 | 06:25 AM
Fiecos Dan's Avatar
Fiecos Dan
1mm skim off the head and block, will need more than 1mm off the pistons to get c/r back the same.
if its detting, it isn't setup for the newer spec.
Old Jul 13, 2007 | 11:13 AM
drsrst2zvh's Avatar
drsrst2zvh
Well im going to do a compression check on my own car tonight as i know mine is spot on, then do the same test on my mates with the skimmed pistons and see if his is much higher than mine then i think that will show my thoughts are right and the comp is to high, ive been told anything below 150 psi is ok for 1 bar any higher then
Old Jul 13, 2007 | 07:32 PM
Fiecos Dan's Avatar
Fiecos Dan
that wont show the cr.
as too many variables, ie cam, cam timing, rings, valves, battery, starter.
Old Jul 14, 2007 | 08:38 AM
drsrst2zvh's Avatar
drsrst2zvh
both cars are the same so it will show the difference in the two and thats all i need to know
Old Jul 14, 2007 | 11:53 AM
zippyobrien's Avatar
zippyobrien
not neceserally, your car might have lower compression as you havnt stripped yours down to change the rings, where as your friend would have when he had the pistons machined,
as dan said, its probly down to the set up, are you both using the same turbo, ?
Old Jul 14, 2007 | 12:39 PM
drsrst2zvh's Avatar
drsrst2zvh
no he is using a stage 3 hybrid turbo with a -31 but the boost is set just under a bar wich is not very much considering, im doing the comp test this afternoon so ill post the results up and see what you lot think
Old Jul 14, 2007 | 04:32 PM
drsrst2zvh's Avatar
drsrst2zvh
right done the comp test and the de comp plate engine done 150 psi which ive been told is right but the skimmed piston engine done 180 psi so is way to high
Old Jul 14, 2007 | 07:04 PM
Fiecos Dan's Avatar
Fiecos Dan
Why is it too high?
As i said depends on too many things.
my 1600 cvh running std comp ratio is 175psi on std cam, times to 104 degrees, 155 psi at 112 degrees. and 165psi on kent 35 cam @ 118 degrees.
All on same day, using same tester and method, with booster connected.
He's running a larger turbo, on un set up car, and unknown engine C/R, IT NEEDS SETTING UP.
Old Jul 14, 2007 | 08:48 PM
drsrst2zvh's Avatar
drsrst2zvh
Why is it too high?
Cheers for the reply's but its not always just get it set up, ive spoken to lots of engine builders today and 2 rolling roads and they all said the same it should be no more than 150psi and with it at 180 its to high and causing it to pink, one rolling road was torque of the devil and chris todd told me this as he's done loads and he said he wouldnt touch it until the comp's been lowered
Old Jul 14, 2007 | 08:53 PM
Fiecos Dan's Avatar
Fiecos Dan
Ok, i'll stop wasting my time posting.
But low comp is not needed, if set up correctly. i've run 10.5:1 turbo CVH's before. and guess what @ 10psi it didn't det.
Old Jul 14, 2007 | 09:07 PM
drsrst2zvh's Avatar
drsrst2zvh
No i didnt mean it like that, i bought an rs turbo years ago with a standard non turbo cvh lump in it but runing all the turbo stuff and that pink'd its head off when you tried advancing the timing it was set that far retarded to stop it pinking it wouldnt pull the skin off a rice pudding so thats what made the alarm bells ring
Old Jul 14, 2007 | 09:14 PM
Fiecos Dan's Avatar
Fiecos Dan
If you go to a RST tuner that can re write the ign chip, then being retarded on boost isn't a issue, unless EGT's start getting too hot.
i honestly think you should retard timing till it stop's the det, and measure the static timing.
it can be detting for more than just C/R, ie.
- fueling,
- too advance timing,
- ecu fault/ ecu not ready boost correctly, could be a boost leak between inlet and ecu.
Old Jul 14, 2007 | 09:29 PM
drsrst2zvh's Avatar
drsrst2zvh
- fueling,
timing is retarded now so i can elliminate that one and i will try my bro's ecu on it tomoz as i know that works fine
Old Jul 14, 2007 | 10:30 PM
Fiecos Dan's Avatar
Fiecos Dan
How retarded?
is it chipped or on std ecu? as if its not chipped for spec, then it will run retarded off boost to cure det.
Old Jul 15, 2007 | 07:21 AM
drsrst2zvh's Avatar
drsrst2zvh
How retarded?
Dizzy is set under half way back and yes the ecu's are chipped, the cars are the same in every way the only difference is that my bro's one has the green knock sensor connected on his and the other car hasnt got the sensor the manifold hasnt got the fittings in it for one but it does have the plug from the loom but ive been told if its not connected it wont sense anything and there for make no difference
Old Jul 15, 2007 | 09:05 AM
Fiecos Dan's Avatar
Fiecos Dan
So one is a S1 engine in a s2, the other is a s2 in a s2.
What chips are fitted, how do you know they are chipped, have you had the ecu's checked?
How retarded? you haven't measured it, so how do you know how retarded it is?
Have you removed the cam, and check it is std? have you set the cam timing on adj verniers on each car? as ones been apart and most prob a skim, and the others got a comp plate,
In which case what cam timing figures have you used?
If been done with std marks, 1) cam timing wrong, so compressions wont be the same, 2) as cam timing wrong the ign will be out too, unless set up with a timing light, or det checked by a skilled person.
If neither of the above is done, they both aren't tuned/set up.
Old Jul 15, 2007 | 09:27 AM
drsrst2zvh's Avatar
drsrst2zvh
the engine was out a d reg series 2, standard cam yes, i havnt used adj pulley, the cam is set at dot and the block is set at tdc with a dti gauge which is what i was told to do by kr engineering, so if the block is set at tdc where should the cam be then ?
Old Jul 15, 2007 | 09:41 AM
Fiecos Dan's Avatar
Fiecos Dan
The cam marks are only for a std, un touched engine, but even then, they arn't that accurate.
so as soon as its been skimmed, or de comp plate fitted, your not be able to get the mark spot on.
So the cam needs dialing up with a dial gauge and a adjustable vernier to get it spot on.
Then the ign timing needs setting @ 900 rpm, @ 12' static timing, (or if chipped, what ever the chip manufacture says)
But ideally needs setting up with Det cans whilst on boost.
Old Jul 15, 2007 | 10:17 AM
drsrst2zvh's Avatar
drsrst2zvh
yeah i know what your saying you cant get the arrow to line up with the dot some times, i must just of been lucky and it lined up spot on,
Old Jul 15, 2007 | 10:22 AM
Fiecos Dan's Avatar
Fiecos Dan
still doesn't mean it timed accuaratly.
Old Jul 15, 2007 | 10:25 AM
drsrst2zvh's Avatar
drsrst2zvh
one quick question for you though, if i couldnt get the marks to line up and needed a adj pulley would i set the block at tdc then line the head up with the standard pulley to dot then fit the adj pulley on so i can get the belt to fit without moving the cam and block ? cheers.
Old Jul 15, 2007 | 12:27 PM
Fiecos Dan's Avatar
Fiecos Dan
you could do, but wont be as accurate as it would be it dialed up correctly.
Fit cam pulley (needs to ne on correct timing) and belt and tension belt.
Basicly, you have to spin the crank pully to the set degrees (as quoted by the cam manufacture, or ford, on CVH usually 104 - 120 degrees, depanding on cam fitted).
Then undo vernier adj bolts, spin the cam to get No 1 inlet valve at full lift, using dial gauge.
- spin the engine to make sure belts tension'd correctly all round, and no valve to piston.
- then double check the cam dialed correctly.
- run up, get warm, and set the idle, mixture, ign timing.
Old Jul 16, 2007 | 08:02 AM
b_kennedy's Avatar
b_kennedy
Im using a decomp plate and mine runs sweet. Never had a problem (touch wood). I'm running about 16 psi at the mo.
Was told it could take 20. Any truth in that???
I dont wanna push my luck
Old Jul 16, 2007 | 09:21 AM
drsrst2zvh's Avatar
drsrst2zvh
Well the engine with the decomp plate (the one in my sig) is running just under 1 bar round 12psi and it goes like stink. When i built mine i was told be the engineering company that it would run a bar all day long on standard pistons anything more it would start to melt psitons.
Old Oct 5, 2007 | 05:41 PM
coswurv's Avatar
coswurv
An update on this s2 zvh engine, i have pulled the head off and fitted a 1.5mm decomp plate to it, i have put it all back together and run it up. Took it for a spin and the pinking has stopped but if i advance the dizzy to much and increase the boost more than .7 of a bar i can get it to pink in 4th and 5th, so do you guys think this problem can be solved by a rolling road set up as i didnt think there is actually much you can play with on the s2 mfi set up, any info much appreciated
Old Oct 5, 2007 | 06:16 PM
MarkXr's Avatar
MarkXr
Dan, do you have a decent way to determine the cranks TDC with the head on? If so, would you be so nice to describe it here....??
Thank you in advance.........
Old Oct 5, 2007 | 06:23 PM
Fiecos Dan's Avatar
Fiecos Dan
A setup, and/ or maybe a chip for your spec will sort it.
A dial gauge thro the spark plug hole.
(will need a extension on the dial gauge)
Old Oct 5, 2007 | 07:27 PM
coswurv's Avatar
coswurv
exactly what i thought dan to be honest, im taking it to the pf rolling road day tomoz so i can get an idea of what it needs, you going ?
Old Oct 5, 2007 | 07:42 PM
juffer's Avatar
juffer
what power figures are you guys running?
Old Oct 5, 2007 | 08:06 PM
coswurv's Avatar
coswurv
Well they havnt been on the rollers yet so im not sure, will let you know tomorrow when i get back from the PF rolling road day.
Old Oct 6, 2007 | 08:32 AM
Fiecos Dan's Avatar
Fiecos Dan
I'm not sure how good PF are with RST's now, after the rr, i would take it to your decided tuner and go from their.
Torque of the devil, APT, or any other good tuner who's worked with the MFI/RST alot.
Old Oct 6, 2007 | 12:41 PM
Badman38's Avatar
Badman38
Why is it too high?
m8 if the mappers good at his job ( there rae a lot of crap mappers out there) tehn you could run a turbo engine with high comp and no det how do you think wrc cars run also look at andy nicolls rover c/r 10:5:1 and he runs 35psi on a gt35
sean
Old Oct 6, 2007 | 07:10 PM
coswurv's Avatar
coswurv
Old Oct 8, 2007 | 03:23 PM
rstdave's Avatar
rstdave
Turboboss: Spot on there mate....the jap guys have bin using high comp engines for a while and even cossie owners/tuners are realising that u don't need to run 7:1 c/r to run a load of boost!! One of the reasons evo's and the like are so quick.....and how they make power with less boost than cossies etc!
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Bailes1992
Aug 16, 2015 07:14 PM
155lee
Aug 14, 2015 11:21 AM
