saph cos 4*4 wheel bearing UPDATE
Old Jul 12, 2007 | 07:10 PM
SS1's Avatar
SS1
Default saph cos 4*4 wheel bearing UPDATE
any ideas where and how much please .needed for nearside front
reason i am asking was in fords to today and bloke said part number is 5013161.. £63 but then he umd and ard for a bit and said its for a 2 wheel drive and there is no locking crown nut with it "the locking nut "....you best ask around and then come back he said
is there a difference between front nearside and front offside..left and right & handed threads iirc
and can i get the full KIT in one go anywhere
cheers
Old Jul 12, 2007 | 07:17 PM
dojj's Avatar
dojj
Resident Wrestling Legend
fronts are the same
same as the XR4x4's too
best to get the ford ones as the motor factor ones tend to last a lot less
Old Jul 12, 2007 | 07:32 PM
SS1's Avatar
SS1
dojj
so i guess they sell the locking cap separately then
cheers but you dont really help as he didnt seem to know the correct part number the bloke in FORDS
Old Jul 12, 2007 | 07:36 PM
iansoutham's Avatar
iansoutham
OCD Victim
5013161 is the correct finis for a Cossie 4wd wheel bearing kit.
6036437 is the finis for the driveshaft nut.
... and as Dojj says, the Ford ones generally last longer, plus if they go under warranty and you have the receipt, they are obliged to change it FOC.
Old Jul 12, 2007 | 07:46 PM
dojj's Avatar
dojj
the nut needs to be tightened up and then "staked"
which means you can't reuse them really
also, make sure you don't overtighten them this tends to strip the threads on the shaft
Old Jul 12, 2007 | 07:58 PM
SS1's Avatar
SS1
iansoutham
nice one
dojj
cheers again
Old Jul 12, 2007 | 09:38 PM
CosKev3's Avatar
CosKev3
Used motor factors ones in mine with no probs
Bearings were made by Timken,probably the same as the Fords ones if you look
Just boxed up in Motaquip boxes
£27 a side,which includes both left hand thread and right hand thread nuts,so the kit can do either side
Old Jul 12, 2007 | 10:09 PM
SS1's Avatar
SS1
CosKev3
fuck that nearly £40 cheeper and i guess the fella on the desk will know more about what hes selling
not really arsed about the price tbh just what all the parts in one go
i will try a few factor shops tomorrow on the phone before calling down
nice one KEV
Old Jul 13, 2007 | 09:54 PM
CosKev3's Avatar
CosKev3
Originally Posted by avid-fan
CosKev3
nice one KEV
No probs
How did you get on?????????
Old Jul 13, 2007 | 10:21 PM
Andreas's Avatar
Andreas
Doubt it have to be a Ford item to last. Friend of mine fitted SKF, cant get much better than that.
Old Jul 19, 2007 | 09:08 PM
SS1's Avatar
SS1
gets a phone call today from the motor factors stuffs in
but no locking nut supplied nice
so trundles off to fords again nuts in stock only £1.78......... 6036437 is the finis for the driveshaft nut.
its got a N stamped on it "i presume that means nearside"
so said to the bloke give me two for the left and two for the right hand shaft please
and he says THERE BOTH THE SAME ON EACH SIDE MATE
now as coskev said "which includes both left hand thread and right hand thread nuts,so the kit can do either side"
what is this bloke smoking in fords ????
i fucking GIVE UP
Old Jul 19, 2007 | 09:11 PM
PAUL S's Avatar
PAUL S
the bloke in Ford is correct - the fronts on the 4x4 are the same nut either side, its the 2wd fronts that are handed, plus the rears on all versions are handed
The actual bearings and cups are all the same front and back, its only the seals that are different in the kits and the nuts
Old Jul 19, 2007 | 09:22 PM
iansoutham's Avatar
iansoutham
OCD Victim
Old Jul 19, 2007 | 09:28 PM
SS1's Avatar
SS1
yes all well and good but i thought that ment just the nearside locking nut
i thought coskevs car was 4*4 as the thread title stated.hopefully i am wrong then
ta for the code number btw
Old Jul 19, 2007 | 09:39 PM
iansoutham's Avatar
iansoutham
OCD Victim
No probs, anything else like that, just let me know and I'll try to sort the finis numbers for you....
Old Jul 20, 2007 | 03:51 PM
CosKev3's Avatar
CosKev3
Thats right
My current car is 2wd,changed all bearings on that last winter
Few years since I owned a gay 4x4,sorry
malkiemac3579
Jul 14, 2017 12:10 PM
3dr cossie
21
Nov 20, 2015 05:00 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
ray barker
Aug 7, 2015 09:00 AM
muz
Aug 1, 2015 06:48 AM
