help please.....
Old Jul 10, 2007 | 06:45 PM
george escort's Avatar
george escort
Default help please.....
hello everyone i have a problem
i have just blown my 1.8 zvh up it was my falt i was running on standard set up for a 1.4 cvh efi / pte efi with max fuel pressure it went well but went pop after bout 2k miles it got some stick tho
so i have bought...
piper t285 ultimate road cam kit
piper vernia pully
severn valley motosport 1.8 zvh block running low comp cast pistons
ported / polished frst efi head (frst)
efi inlet/throttle body (frst)
front mount intercooler ..can give mesurements
beuge injectors
and gettin ofac ecu off crazycage on here i hope
and still have my t34 turbo
i have an efi loom in my car the only differances i can see are the cvh/pte engine uses crank angle and cam sensor with maf sensor were as the frst management uses just crank angle and map sensor that is the only differance i can see the frst ecu plugs strate into the loom but mothing happens ( i tried my mates) is it just a case of forgetting about the cam sensor and getting the 2 wireing diagrams and swapping a few wires about at the ecu plug and running map i have a frst map sensor in my workshop i think any help will be wicked guys and gals
Old Jul 10, 2007 | 06:52 PM
george escort
forgot to mencion it is a mk6 escoort and i have another new ap organic cluthc aswell..
Old Jul 10, 2007 | 11:25 PM
SafeChav's Avatar
SafeChav
You'll have to get the diagrams out and check all the wiring, probably not the most straight forward of jobs though being as the 1.4 uses sequential injection and the MAF.
And silly boy for trying to run it on standard management
Old Jul 11, 2007 | 06:50 PM
george escort
diddent know the frst wasnt sequential aswell
Old Jul 11, 2007 | 07:42 PM
crazycage's Avatar
crazycage
im sure it is
Old Jul 12, 2007 | 11:22 AM
SafeChav's Avatar
SafeChav
Nope, FRST's fire in batch, the same way the coil sparks.
So you will get half the mixture required squirted with the inlet valve closed, and the other half when the valve is open.
Old Jul 12, 2007 | 12:42 PM
crazycage's Avatar
crazycage
what can i say !you learn something new every day
Old Jul 12, 2007 | 01:18 PM
SafeChav's Avatar
SafeChav
K464TGV
Jul 2, 2014 09:30 PM
Cossy Mike
Sep 10, 2013 11:17 PM
Rob Virgo
Sep 27, 2012 02:49 PM
RSEDD
Nov 17, 2011 05:07 PM
Greg_D
Mar 3, 2011 11:53 AM
