Running without ECU's on escort rst
Hi guys i have heard from someone that his mates yonks ago used to remove both of their ECU's off of there erst's and they would still run? I have converted my car to EFI and the engineering shop fudged up the inlet manifold and its going to take me forever to sort it out. It may be easier to sell off my EFI stuff and just chuck an airflow meter back on. I dont have the wiring available so i'm just wondering will it work and how do i do it and what problems are associated with this?
It is impossible to run without the silver ECU, as this acts as an ignition amplifier. It is "possible" to work without the Black fuel ECU.
If you are willing to get the car to manchester, i can get going any way u wish, mfi or efi.
Rick.
Rick.
Originally Posted by _DAN_
Do RSTs run two ecus then? I know nothing about them.
Silver is the ignition ECU and the Black one is the fuel ECU
Ah right, i guess you could slap on a dizzy then. to get it working without the fuel computer would i need to have 2 connect up an electrical supply to fuel meter?
off the car the air-flow meter's flap won;t open, is this 'released' by fuel pressure or an electrical supply?
I am really skint atm and can't afford 2 put it on the road as it is. If this will work i can get it running for now and then go back to EFI later!
Its only a temp bodge for now.
And you forgot to mention it will run like the biggest pile of poo ever without the fuel ecu
Yea, i never bothered with a choke on the DCOE's, ive wired in a lambda sensor to an O2 meter on the dash. This might just be a quick fix until i can afford to finish the EFI installation. I may run it with a dizzy aswel and adjust the bob weights to get the right timing at higher rpm.
