torque wrench settings
Old Jun 23, 2007 | 07:07 AM
grayfezzie's Avatar
grayfezzie
Default torque wrench settings
Hi
dose anyone know the torque setting in Nm for the big-end bearing caps and main bearing caps for a escort rs turbo?
regards gray
Old Jun 23, 2007 | 10:02 AM
Rick's Avatar
Rick
30Nm for big end caps, 95Nm for Main caps.
Old Jun 23, 2007 | 04:19 PM
Aaroncast's Avatar
Aaroncast
THE MANUALS ARE VERY HANDY!!-GURU7002 E BAY
Old Jun 23, 2007 | 06:36 PM
dissmalrs's Avatar
dissmalrs
hi mate the setting 4 the mains all of these are from the haynes cvh rebild and tuning manual
main bearing caps 90-100 nm
con rod bolts 30-36 nm
flywheel to crank 82-92 nm
crank pully 100-115nm
that is for standard bolts if there arpones thay will habe the settings in the packet
hope thats a help if u need any more i have them all
cheeRS darryl
Old Jun 4, 2013 | 05:07 PM
terry10w's Avatar
terry10w
Hi guys ive used these settings but engine refuses to turn over any ideas cheers
Old Jun 4, 2013 | 05:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
As in you cannot turn the crank using a spanner? Or it turns freely but the starter motor won't spin?
Assuming you mean the former then check your bearing clearances, sounds like the shells might be nipping the crank.
Old Jun 4, 2013 | 06:45 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Did you use standard shells or oversized and also did the shells go in dry or wet, as Karlos pointed out will it turn by hand at all
Old Jun 5, 2013 | 11:43 AM
Red_bull's Avatar
Red_bull
i think even with dry bearings it will spin and also torque settings won't make the problem. It's more likely that one of your measurements went quite wrong. Wrong bearings i would say
steve.rst
Mar 15, 2016 08:01 AM
lime
Sep 25, 2015 06:56 PM
IainRS1700T
Sep 25, 2015 06:44 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
JamboRS
28
Sep 14, 2015 09:02 PM
