engine problems!
Old Jun 11, 2007 | 02:26 PM
joshF's Avatar
joshF
Default engine problems!
jus got myself a escort for a project cleaned it up polished it.thought id clean the air filter then noticed the carb had all sludge in it so took the rocker off to see what that was like and thats all coverd aswell.and the gastket had gone all i can think is water mixing with oil
what u reckon?
Old Jun 11, 2007 | 03:23 PM
cozmeister's Avatar
cozmeister
More boost Igor!
That's some top quality emulsification!
Don't like the look of all that oil in the carb
Old Jun 11, 2007 | 04:16 PM
It is 1100/1300 ?
It is valencia engine, it is a very known problem for cars doing short trips and using crappy/cheap oil.
They eventually break the rocker shaft, due to lack of lubrication.
Try some wynns flush, then refill with decent oil and get it nice and hot.
I used VALVOLINE in my escys and the inside of the r/cover was spotless, after this.
Old Jun 11, 2007 | 04:42 PM
joshF's Avatar
joshF
1300 onli did 600 mile last mot.cheers mate il try that 2moz shall i clean out the carb and get most of the crap out b4 though?
Old Jun 11, 2007 | 08:16 PM
Yep get it all clean, and remember the oil needs to be change twice a year at least regardless of mileage.
An old trick was to put soundproofing felt around the rocker cover by making it a little jacket to keep it nice and warm!!, it works as well, did it on my minis as well.
Old Jun 11, 2007 | 08:23 PM
joshF's Avatar
joshF
kk il clean it all tommorow i no it has had cheap oil and never been warm coz my old man used it.he onli did like a mile here and there so it never got warm.il have to get a new gasket aswell.i reckon the hard part is gonna be cleaning in the top the carb shouldnt be to bad.
anyway cheers mate
Old Jun 12, 2007 | 06:31 AM
Just use a CARB CLEANER spray very effective, don't overtighten rocker cover!!, or it will distort and leak.
Old Jan 17, 2009 | 08:41 PM
RSturboJET's Avatar
RSturboJET
Can't Find 'em? Grind 'em
Originally Posted by tabetha
It is 1100/1300 ?
Not the valencia, but it's daughter- the HCS
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
