HELP! Gearbox problems
Old May 29, 2007 | 06:28 PM
marsh9's Avatar
marsh9
Default HELP! Gearbox problems
i'm getting a tapping noise when i reverse my Focus, which is now gradually getting louder, it also seems to 'slip' out of gear occasionaly. i'm thinking that maybe one of the teeth on the reverse cog has sheared off. does anybody know if i can just replace the cog, or will i need to change the whole gearbox?
Old Jun 19, 2007 | 11:24 PM
phill295's Avatar
phill295
a gearbox specsalist would be able to just change the reverse idler and syncro but some place wont touch internal problems on a gearbox
Old Jun 20, 2007 | 06:59 AM
A gearbox place can do just a repair on the defective bit or a whole recon just discuss, but remember that a repair only warrants JUST the repair NOT the hole box.
How many miles ?
Old Jun 25, 2007 | 04:12 PM
marsh9's Avatar
marsh9
about 57,000 miles, not too bad for a '99 but little problems starting to pop up more often now.
cheers
Old Jun 25, 2007 | 08:08 PM
SafeChav's Avatar
SafeChav
Sounds like its stripped a few teeth off the reverse gear to me if its making a noise like that.
Probably be worthwhile having the whole thing reconditioned/changed sods law you'll have reverse gear done and then one of the forward gears will go
TPM961
Jan 15, 2018 10:50 AM
Flateric_2002
Sep 15, 2015 08:41 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
gingeRS
Sep 4, 2015 06:29 PM
