can i....
Old Sep 20, 2004 | 06:16 PM
James_RST's Avatar
James_RST
Default can i....
wiring people....
can i run a wire from the temp sender unit to the multiplug in the back of the dash clocks to get the temp guage working?
or does the wires from the temp sender go somewhere else before it goes to the dash clocks?
Old Sep 20, 2004 | 06:19 PM
Dave Henshall's Avatar
Dave Henshall
should be able to - why though? is there a break in the wiring loom ?
Old Sep 20, 2004 | 06:23 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
he has no wire their that he can find for the temp guage.
Old Sep 20, 2004 | 06:29 PM
Dave Henshall
ah, yep, no probs.. you'lll probably find if you cut the loom back it has snapped off (under the bonnet)as they are only a single wire out on its own. onto the push on post connector.
Old Sep 20, 2004 | 06:44 PM
James_RST's Avatar
James_RST
as dave says i cant find anywiring for the temp sensor that is obvious so i presume its broke off and been taped over or its been cut off and taped over, either way i dont fancy unwrappind the loom to find it. cheers though so its just 1 wire from the temp sensor to one of the bits on the multiplug on the dash clocks? if so that seems a simpler idea rather than unwrap the loom i think ill just get a new connector and wire it to the multiplug on the clocks.
Old Sep 21, 2004 | 07:35 AM
Dave Henshall
YEP - INDEED AS ITS EARTH PATH IS THROUGH THE ENGINE ITSELF.
Luca
4138
Mar 14, 2025 03:29 PM
RS_JASE
Aug 13, 2008 09:26 PM
bigpower
Mar 15, 2008 06:36 PM
biglee
76
Sep 8, 2006 09:52 AM
auralisRS
Ford Escort RS Cosworth
15
Dec 3, 2005 03:17 PM
