help needed on cossie engine please
Old May 23, 2007 | 05:52 PM
Gary Osborne's Avatar
Gary Osborne
Default help needed on cossie engine please
im just about to start my friends newly built cossie engine for the first time , but he has just informed me that the engine builder put a bung in the hole directly under the breather hole in the cam cover.
im assuming its a breather to vent crank case pressure and should deffo not be blocked?
also this car has no hole in the cam cover. why was it on some cars and not others?
where does the crank case pressure go when the cover has no hole?
help please as he thinks its fine and im being stupid
Old May 23, 2007 | 06:04 PM
Gary Osborne
please
im sitting here with the keys in the ignition... cant fight the urge for much longer
Old May 23, 2007 | 06:10 PM
xr4x4rs's Avatar
xr4x4rs
does it have a hole in teh top of the cam cover?
as std no cosworth did
but under the rocker cover they all have the hole ready to be drilled out for an atermarket breather system
Old May 23, 2007 | 06:12 PM
Gary Osborne
ah i see
what about the hole in the head though. i take it should not be interfered with and left open
Old May 23, 2007 | 06:13 PM
xr4x4rs's Avatar
xr4x4rs
yes
should just be left opening
Old May 23, 2007 | 06:15 PM
Gary Osborne
thank you. hope the bitch fires up now
Old May 23, 2007 | 06:17 PM
RichieST's Avatar
RichieST
sure i just saw a cossie bonnet and cam cover orbit over my house
Old May 23, 2007 | 06:22 PM
Gary Osborne
did they look irish
she fired up. everything fine so just need to whip the cover off and invetigate how he blocked it.. fookin farmer mechanics
JoeyBoyden
Jan 4, 2024 02:36 PM
kosienutter
31
Aug 22, 2015 09:55 AM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
