Broke Cossie Brakes
Old May 7, 2007 | 08:38 PM
BigErn's Avatar
BigErn
Default Broke Cossie Brakes
My lucky streak just keeps on going
Took my car for a run down to York today and on leaving, just outside of the drag strip my ABS and handbrake light came on. I pulled over and could see nothing wrong so had no choice but to carry on driving and things were working fine, about 10 minutes after that I went to slow for a roundabout and my pedal was totally solid as if the ignition was off. Needless to say I shat my pants. :cry I pulled over, couldnt find anything amiss but the handbrake light on and ABS pump was going mad. I unplugged all the plugs to the brakes so I could limp it home with its solid pedal and virtually no stopping power at all.
I got it home and had a look about it and can still see nothing wrong, plugged things back in and the pedal is still rock hard, anyone had this or got any ideas??????
Old May 7, 2007 | 09:31 PM
dakar's Avatar
dakar
Might be the servo
Old May 7, 2007 | 09:50 PM
scortmad's Avatar
scortmad
it will be the abs pump or fuse, also check for power at the pump there should be a plug on the 2 wires coming from the pump they should be + and - with the ingnishion on
Old May 7, 2007 | 10:31 PM
BigErn's Avatar
BigErn
I have posted this in the GD section too, few peeps think ABS unit has gone.
Old May 7, 2007 | 11:34 PM
scortmad's Avatar
scortmad
100% it is .but please check you have power and the fuse is not blown first before riping it all off
Old May 11, 2007 | 07:16 PM
rallyeweezle's Avatar
rallyeweezle
Sorry to butt in, im new round here I had the same problem a few weeks ago what had happened was the break fluid had cooked and over flowed out of the reservoir pushing the level sender up so far it got stuck all I did was wait for the fluid to cool then unjam the sender. God bless heat soak….. I think not!
Dan
Old May 11, 2007 | 10:09 PM
tonto's Avatar
tonto
Servo?Anyone who knows anything about cossies should know they don't have servo's.
It will definately be the fuse or the relay.The ABS unit does not fail and I have never heard of the pump to fail
Paul.
Old May 12, 2007 | 12:28 AM
The fact that the pedal is hard but the pump is pumping, and should be developing pressure suggest the pump is knackered.
PUMPS can go as can ABS units, all parts can fail the pumps especially so if the car has no heatshield.
Old May 12, 2007 | 05:41 AM
2001ode's Avatar
2001ode
Hi,
As Tabetha say, another possibility is accumulator defective.
If rubber separator in accumulator is defective, you have no pressure reserve. The pump run and stop in very short lap time.
Note that ABS module and pump are completly separated. You can disconnect your ABS module and the pump run still.
Regards.
Claude
IainRS1700T
Sep 25, 2015 06:44 AM
wattie
Sep 16, 2015 11:34 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
