Am i lucky or unlucky, place your bets..... (engine failure)
Old Apr 19, 2007 | 04:09 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Default Am i lucky or unlucky, place your bets..... (engine failure)
Well the snotty old YB I through into my 3door as a temporary measure has died, but the question is, can it be resurected?
Symptoms:
Engine still runs fine, goes really well
Water is coming from between the block and the head
The coolant is full of oil (lovely brown sludge)
I figure its one of the following:
a) Head gasket
b) Cracked Block
c) Cracked head
Its a 205 block, on ARP's
Going to pull it apart tonight, but what does everyone think will be the outcome, will it be back together tomorrow evening with just a new headgasket, or am I going to need a new block and/or head
*jap accent required for next line
Prace Bets Now...........
Old Apr 19, 2007 | 04:16 PM
Deleted by Request's Avatar
Deleted by Request
Former Sponsor
...are you saying its spraying out?..is it the rear corner exhaust side as its common there...but sorry to say your block has cracked between the head bolts
Old Apr 19, 2007 | 04:18 PM
Smit's Avatar
Smit
The 60ft Launch King
Head cracked between valve seats......
Deleted by Request
Former Sponsor
..to add did you put the head on...if so what did you torque the arp's to and was it with or without moly grease?
Old Apr 19, 2007 | 04:22 PM
dave cos4x4's Avatar
dave cos4x4
i would say its cracked too.
Old Apr 19, 2007 | 04:47 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
ARP itous by the sounds of it
Old Apr 19, 2007 | 05:56 PM
Chip's Avatar
Chip
Just took the head off, looks like its only the gasket.
Gone between the oil and water ways but not the combustion chamber.
Probable cause by the looks of it is corrosion, which will be my fault as I ran in the summer without antifreeze in it for ages.
Lesson learned there then, lol
Old Apr 19, 2007 | 05:59 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
t t t.....u do need the big A/F in a cos lump.......shame on u...get it fixed and get it abused
Old Apr 19, 2007 | 06:22 PM
Chip's Avatar
Chip
Hopefully get it back together tomorrow night as busy during the day
I already knew full well about the antifreeze, but you know what its like if you have none of it on the shelf and you change a hose and then want to use the car, lol
Phil, cant remember what torque settings I used for the ARP's, whatever I was recomended off here at the time, think I used the grease last time but if I havent got any spare this time I will just do it with the oil setting (is it 100 for oil and 80 for arp lube IIRC?)
Will get on the lookout for the bits to rebuild the 200 block up properly as soon as the nova and calibra are finished (hopefully in june) as im sure although I was lucky this time, its only a matter of time for this engine.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
