Series 2 over fueling
Old Apr 16, 2007 | 09:16 PM
stusfesta's Avatar
stusfesta
Default Series 2 over fueling
hi basically i bought a series 2 and it was missing the ecu and few little bits. got an ecu but it runs really rich and hardly starts, when it does start it chucks out loads of black smoke and can smell the petrol. Is there any way i can adjust the fuel? have tried adjusting metering unit but no good. When i disconnect the petrol pump it runs lovely for those couple of seconds so its gotta be the fueling. anyone help?
Old Apr 16, 2007 | 10:46 PM
cossie604's Avatar
cossie604
you tried unplugging the cold start injector (the blue one)?? Ive had this jam open before when i had rst's in the past.
Old Apr 17, 2007 | 12:06 AM
SafeChav's Avatar
SafeChav
You may well find your metering head is knackered, i had one that overfuelled on one cylinder. See if you can get the emissions down but if its reading eratically you could well need a new metering unit.
The cold start injector only operates when the key is held in the cranking position, so unplugging it wont make a difference because it doesnt spray fuel once the engine is running. And if its stuck open it will be because its knackered internally, not an electrical fault.
Old Apr 18, 2007 | 07:10 PM
gup's Avatar
gup
have you put the correct wires to the correct sensers on the back of the inlet
Old Apr 20, 2007 | 05:53 PM
stusfesta's Avatar
stusfesta
I have tried swappig the connecters around but still no joy, i bet it is something silly but dont know what!
Old Apr 20, 2007 | 09:14 PM
SafeChav's Avatar
SafeChav
Check you have all the wires connected on the battery, if you leave the small thin wires off they run like poo
Old Apr 21, 2007 | 08:22 AM
stusfesta's Avatar
stusfesta
yea checked that too. if i stop the fuel pump the engine runs as it should ror that 1 second so its definatly fuel prob
Old Apr 21, 2007 | 11:14 AM
CabrioTurbo's Avatar
CabrioTurbo
you can adjust the fuel fressure on the fuel pressure regulator but i wouldnt attempt this unless you have some way of measuring co... you will likely melt the engine on boost if you do~!
Old Apr 21, 2007 | 04:40 PM
davidreader5's Avatar
davidreader5
Hi,
The s2 fitted with mfi, does not have a adjustable fuel regulator as efi,
the fuel pressure can be played with through the fuel pressure actuator
connected to the metering unit, could be cold start valve or thermo time switch that runs the cold start valve, fuel pressure related which you need some decent kit to test primary and differential pressure hot and cold test, for KE system,
to see what is at fault ie regulator/ fuel pressure actuator/ metering unit(fuel distributor)
you could also have a bad coolant temp sensor which tells the ecu one of the ecu's what temp the engine is and it uses this as info for running the engine, loads of things really, you need someone who knows the system,
to check it out,
Regards Dave R.
Old Apr 25, 2007 | 09:46 PM
stusfesta's Avatar
stusfesta
bump! still no luck
Old Apr 25, 2007 | 09:48 PM
SafeChav's Avatar
SafeChav
Have you tried another metering unit?
Old Apr 26, 2007 | 01:05 PM
Gti Killer's Avatar
Gti Killer
hi all
sounds like the same problem i had could get my car to keep running after it got run a little changed everything even the cam as i was running std cam on chipped ecu any way my motor was running rich and kicking out black smoke when under load and stunk of petrol like you i tried to sort out the over fueling was told to pull out the multi plugfrom the fuel pressure acuator whilst the car is running and it run fine no fuel smell no black smoke and it run fine give this a go and see if it works if it does you could need a new pressure acuator hope this helps.[/u]
Old Apr 26, 2007 | 08:11 PM
stusfesta's Avatar
stusfesta
ah ile give that a go. forgive me for bein dunce but which one is the pressure actuater?
Old Apr 27, 2007 | 11:05 AM
davidreader5
Hi,
The fuel pressure actuator is on the side of the metering unit, some are
grey and some black,(small square box with electric plug attached)
unplug the connector, when the engine is warm the current is zero,
but you need it for full load enrichment ect, so if it does run ok, you need
to check the system is giving the correct ma, voltage from start enrichment, warm up,etc. it may just be you need a new actuator,or CTS,
Also check the hose from the metering unit to turbo is tight & check the air sensor plate is not sticking in its travel
Regards Dave R.
Old Apr 28, 2007 | 05:38 PM
stusfesta's Avatar
stusfesta
hi
Rite, i spoke to an old fella who has done a lot of work on rst's and he says he is almost certain its the metering unit as it was sat around for a year or so the O-rings dry up inside and just fcuk them up. I did already buy another one but i recon its got same problem. So now i am goin to take my mates off his car and try it so i know for sure. mission!
Old Apr 28, 2007 | 05:39 PM
SafeChav's Avatar
SafeChav
That would be EXTREMELY coincidental to buy another metering unit with the exact same fault..........
Old Apr 28, 2007 | 05:43 PM
stusfesta's Avatar
stusfesta
thats what i thought but if both units have been sat with no fuel in then they will have same prob. I will know for sure once ive tried my mates which runs fine
Old Apr 28, 2007 | 05:47 PM
SafeChav's Avatar
SafeChav
I used a metering unit which had been sat out in the rain for over a year and it worked, admittedly it overfuelled on one cylinder but the car started and ran!
Old Apr 28, 2007 | 06:20 PM
stusfesta's Avatar
stusfesta
lol your just lucky! well im gonna try me mates then i will know then. I dont know what else to try
Old Apr 28, 2007 | 06:28 PM
SafeChav's Avatar
SafeChav
Try it, got nothing to lose have ya.
Im not convinced myself but its worth a shot
Old Apr 28, 2007 | 06:32 PM
stusfesta's Avatar
stusfesta
i will let you know
Old May 3, 2007 | 08:51 PM
stusfesta's Avatar
stusfesta
could it be the ecu? I bought the car without one so could i have bought the wrong one? theres loads of different ones for the erst aint there?
Old May 4, 2007 | 08:35 AM
SafeChav's Avatar
SafeChav
Unlikely, theres only 2 different fuel ECU's anyway
Old May 4, 2007 | 12:01 PM
Gti Killer's Avatar
Gti Killer
look on the back of the inlet manifold and see if a yellow plug is connected or snapped sounds to me like the fueling plug is knackerd
Old May 4, 2007 | 12:05 PM
SafeChav's Avatar
SafeChav
"fuelling plug" ??
Old May 4, 2007 | 02:09 PM
Gti Killer's Avatar
Gti Killer
sorry not fueling plug cold start he he rushing at work at moment
Old May 4, 2007 | 02:43 PM
SafeChav's Avatar
SafeChav
The cold start injector only sprays while cranking, it doesnt operate with the engine running.
Old May 8, 2007 | 09:06 PM
stusfesta's Avatar
stusfesta
but surely not having the rite ignition ECU aint gonna help is it?
Old May 9, 2007 | 12:07 AM
SafeChav's Avatar
SafeChav
the only real difference is the later ones require a knock sensor, they will work without one but the ignition curve is very flat due to massive retard, but its easy to bypass
Old May 10, 2007 | 08:43 PM
stusfesta's Avatar
stusfesta
got another metering unit and it works!! not perfect but just needs a tune.
now got a problem where it wont start once its hot! any ideas?
Old May 10, 2007 | 11:22 PM
SafeChav's Avatar
SafeChav
Could be losing its fuel pressure when you switch off
Old May 15, 2007 | 07:30 PM
stusfesta's Avatar
stusfesta
its ok now, just needs a good run and tune up. cheers mate
timsrs
Nov 13, 2018 11:48 AM
AJC
Oct 8, 2015 11:09 AM
SMILER258
Sep 28, 2015 09:04 AM
