S2 A.B.S removal?
Old Apr 14, 2007 | 04:08 PM
bullsrs's Avatar
bullsrs
Default S2 A.B.S removal?
what needs doing to bypass it, have seen cars with the plastic pipes from the servo blocked off, but it also looks like the a.b.s pumps need the pipes from them connecting together or do i just leave the pumps in place on the box?
any help is appreciated
Old Apr 14, 2007 | 10:47 PM
wul young's Avatar
wul young
you are better just unbolting complete abs system and chucking it m8,then you will need master cylinder from non abs car,xr3i etc,then you will have to renew all brake pipes,and lastly,remove abs relay from under dash so abs light doesnt come on.(job done)
Old Apr 14, 2007 | 10:50 PM
bullsrs's Avatar
bullsrs
cheers
Old Apr 15, 2007 | 08:13 AM
djmillsy's Avatar
djmillsy
Fife Radge
this is what i was told to do
[quote="craig rs"]basically just remove all the belts and everything associated with the abs, i had to take the abs bulb out from behind the dash so there was no light on so it passed the mot, also u will need to block the 2 pipes that run to the abs system out the master cylinder, hope this pic helps.....
Old Apr 15, 2007 | 09:26 AM
nicky284's Avatar
nicky284
whats the advantage of removeing the abs? cant you stop quicker with it and steer if you lock the wheels up?
Old Apr 15, 2007 | 09:27 AM
nicky284's Avatar
nicky284
sp. removing
Old Apr 15, 2007 | 11:43 AM
djmillsy's Avatar
djmillsy
Fife Radge
you can but the abs on the rs turbo isnt worth a wank in alot of peoples opinion mate thats why mines is going
Old Apr 15, 2007 | 11:47 AM
SafeChav's Avatar
SafeChav
Wrong
If its a Series 2 they have unique master cylinders, the biggest size @ 25mm. Just remove the ABS and get some pipes made up to join the gaps where the ABS once was, its very easy
Old Apr 15, 2007 | 11:48 AM
SafeChav's Avatar
SafeChav
Its more a case of Mk4's are wank
You won't find ABS on a Mk3
Old Apr 15, 2007 | 01:39 PM
djmillsy's Avatar
djmillsy
Fife Radge
dont get me started on mk3's my pals one ripped the back end out my mk6 escort last night
Old Apr 15, 2007 | 03:49 PM
SafeChav's Avatar
SafeChav
You what lol
Do share it with us
Old Apr 15, 2007 | 06:24 PM
wul young's Avatar
wul young
Wrong
im not wrong m8,removed loads abs from rsts,i wouldny have told the guy that unless i was 100% sure!!
just 1 query about ur method,there is only 2 copper pipe outlets on abs mastercylinder,the other 2 are plastic pipes,how are joining them safely?
its easier to get 4 outlet cylinder,ie,xr31 etc etc,then there are no joins you can run 1 piece pipes to each corner of the car.eliminating bleeding problems and improving pedal!
Old Apr 16, 2007 | 12:42 AM
SafeChav's Avatar
SafeChav
Wrong
I'm sorry........but........YOU ARE WRONG
The only cars to have a 25mm master cylinder were S2's because they have the biggest brakes in the range. There is no such thing as a 4 port 25mm item, because ABS was a factory standard feature for every car that left the production line.
The only way to do your method is to downgrade the master cylinder size to a 23mm which is just crazy talk.
Old Apr 16, 2007 | 12:45 AM
SafeChav's Avatar
SafeChav
The 2 plastic pipe outlets are return pipes man what are you on about
You take the 2 outlets from the MS, and use your home made pipes to connect these to the T pieces located on the inner wings which make the 2 pipes into 4. Then you get a non ABS reservoir which doesnt have any return holes.
Are you really sure you've removed ABS before because i for one can't say im convinced?
Old Apr 16, 2007 | 12:16 PM
wul young's Avatar
wul young
i couldnt care less whether your convinced m8,im not goin to get into a debate with you!!
you are obviously not grasping where i am coming from.so here goes again,your 25mm cyl has 2 outlets,if you are dividing they outlets into 2 pipes each side that means that you are dividing fluid supply by 2 which in turn means more brake effort needed and therefore less brake performance at wheel!!
my method even if it is 23mm,which by the way you will never feel on the road!!
anyway my 4 outlet cyl is still neater job with less hassle than your method and as there is 4 outlets i am getting better brake performance with less effort,if you understand that??????
oh and 1 other thing ive probably forgot more about rsts than you will ever know by the sound of things.
Old Apr 16, 2007 | 12:23 PM
SafeChav's Avatar
SafeChav
lol you stressy fucker
Ive got a good idea everyone, lets downgrade our RS brakes to a 23mm master cylinder
Who else is up for doing that?
Old Apr 16, 2007 | 12:37 PM
Rick's Avatar
Rick
wul young
You are not "dividing" the flow. Using a 23mm master cylinder is daft as hell. Do as Chav says, and simply get a non abs resevoir and t piece in....
Old Apr 16, 2007 | 01:13 PM
Maki's Avatar
Maki
That's the way to do it And by the way that's my drawing that I made few years ago as I was removing my ABS
But stop arguing wul young's way is just one more way ... both ways are good enough, but I thing my way way is easier to do as you just need two new lines
Old Apr 16, 2007 | 01:16 PM
SafeChav's Avatar
SafeChav
The main issue is he is advising people to change down to a 23mm master cylinder. The reason a S2 has a 25mm master cylinder is because they have the biggest brakes of all the Mk4 cars.
Old Apr 16, 2007 | 01:21 PM
Maki's Avatar
Maki
I wouldn't downgrade too but hey it's not worth arguing
Old Apr 16, 2007 | 01:23 PM
SafeChav's Avatar
SafeChav
I'm not the one getting my knickers in a twist over it
After all, wul young has "forgotten more than i know" apparently
Old Apr 16, 2007 | 03:13 PM
wul young's Avatar
wul young
my knickers are fine thanks m8,as said above enough said!!
each to there own eh.
but i would bet anyone that if i had 2 cars side by side,1 with 23mm cyl and 1 with 25mm cyl,not anyone would be able to tell the difference by driving both the cars,i have tryd it both ways.
the 23mm cyl is still a neater and tidier mod in my opinion,neater 1 piece pipes and no joining involved,and equal fluid distrubution to each brake.
Old Apr 16, 2007 | 03:55 PM
SafeChav's Avatar
SafeChav
Neater and more asthetically pleasing - yes
Equal fluid distibution to each cylinder - there is no difference
Difference between a 25mm and 23mm - Ford wouldnt of uprated it to 25mm for the sake of it if they could of got away with fitting the mass produced 23mm item..........
Old Apr 17, 2007 | 07:46 AM
wul young's Avatar
wul young
thats no what im saying!!!!
you would not be able to tell difference,nothing to do with ford or mass production!!!!!!!
we will just agree to disagree on subject then!!!!
Old Apr 17, 2007 | 12:49 PM
SafeChav's Avatar
SafeChav
So answer me this......why did ford fit a 25mm master cylinder to the S2 if the 23mm does an equally good job...............
Clearly your knowledge is better than the millions of pounds a car manufacturer pours into developing a car
Anyway......bullsrs, its up to you what you do but hopefully you can make up your own mind which is the better option. Feel free to give a PM or whatever if you get stuck or want any help
Old Apr 17, 2007 | 01:34 PM
wul young's Avatar
wul young
your asking me a question that is unanswerable now.
i think you should contact ford regarding that one
your jumping to conclusions now!!
i never said my knowledge was better than manufacturer,im just speaking from previous experience with messing around with rsts for last 15 years!!
Old Apr 17, 2007 | 02:09 PM
SafeChav's Avatar
SafeChav
and i think your just avoiding the question because you dont really have a clue what your on about
It wasnt long ago u were bigging yourself up claiming "you have forgotten more about RS's than i know", and now you dont the answer to a fairly simple question
Old Apr 17, 2007 | 02:19 PM
wul young's Avatar
wul young
lol,lol,lol,lol,lol.
your full of shit chav!!!!!
yes i said more than YOU KNOW!!! that doesnt mean more than the manufacturer.
we are speaking the same language are we not,cause i dont know where you are geting these conclusions from????
Old Apr 17, 2007 | 05:58 PM
SafeChav's Avatar
SafeChav
Your full of shit when it comes to the crunch you cant produce any answers.
The fact of the matter is ford fitted a 25mm item for a reason, but you apparently know better.
Old Apr 17, 2007 | 07:53 PM
djmillsy's Avatar
djmillsy
Fife Radge
wul young
im soory but i have to agrre with safechav all this i know more than you bullshit is not going to help this boy fix his motor i value safechav's opinions cause when i comees to the cruch if it wasnt for him then there would be a lot of rs turbos in the scrapper. saying that youve forgot more than he knows is just point scoring if you know more than him then help the people out with there problems yeah you both were right in away both ways would work but this im forgot more than you bullshit will get you knowwhere fast
im not trying to take sides here
Old Apr 17, 2007 | 08:19 PM
bullsrs's Avatar
bullsrs
both seem like damn good solutions,but i didn`t want to cause any arguments,i will get under the car next weekend and see what condition the brake pipes are in to determine which way i will do it.
THANKS for your help
Old Apr 17, 2007 | 08:25 PM
SafeChav's Avatar
SafeChav
Don't be daft you didn't cause the argument
Seriously though, i urge you not to change the master cylinder for a smaller one, if you do though ill happily buy your 25mm one off you because i could do with one on mine, lets put it that way
Old Apr 17, 2007 | 08:41 PM
djmillsy's Avatar
djmillsy
Fife Radge
ive got an s2 master cylinde lying about in an old s2 if your interested pm me
Old Apr 17, 2007 | 09:35 PM
Alex_86's Avatar
Alex_86
hmm, don't know if i did get this right... but to remove the abs.... u want us to change the MS from the 25mm to the 23mm?
Old Apr 17, 2007 | 09:36 PM
djmillsy's Avatar
djmillsy
Fife Radge
thats what hes saying i know i wont be doing that
Old Apr 17, 2007 | 09:39 PM
SafeChav's Avatar
SafeChav
Correct
Old Apr 17, 2007 | 09:52 PM
Alex_86's Avatar
Alex_86
thats insane
Old Apr 18, 2007 | 02:00 AM
SafeChav's Avatar
SafeChav
I know
Old Apr 18, 2007 | 07:55 AM
wul young's Avatar
wul young
ever get the feeling you are going round and round and round and round and round in circles,i do
as i said above each to there own,thats my opinion so either do it one way or the other.
i wont be wasting anymore of my time with this subject as its geting very petty now,lol,lol,lol.
i know my way works and works well,i dont know why you are all disregarding it when obviously no one has tried it
End of..as far as im concerned lads.
Old Apr 18, 2007 | 08:37 AM
djmillsy's Avatar
djmillsy
Fife Radge
no one is degrading it mate just seem a silly thing to do personally remove the bigger master cylinder for a smaller one nice looking car by the way
