clutch release bearing question.....
Old Apr 11, 2007 | 07:08 PM
efiste2's Avatar
efiste2
Default clutch release bearing question.....
I have just installed the new standard clutch onto my Mk4 XR3i engine, and also the release bearing onto the gearbox input shaft, as below
My question is does it need any lubrication/grease around the input shaft sleeve, where the clutch bearing slides, bearing in mind i dont want to contaminate the clutch plates etc etc, The Haynes manual says to put some "MOLYBDENUM DISULPHIDE" grease onto the splines, but mentions nothing about the sleeve
Old Apr 12, 2007 | 12:01 AM
SafeChav's Avatar
SafeChav
Yes you want to put a smear of grease on there, anything more is a waste as it gets scraped off and over time all the dust off the clutch plate will stick to it.
Also put a smear on the fork arms where they sit behind the bearing a carrier, and a smear on the bearing face where it touches the pressue plate springs.
You'd have to seriously go overboard with the grease to contaminate the clutch
Old Apr 12, 2007 | 08:44 AM
RickyLee53's Avatar
RickyLee53
On the splines is just to get the box back off easier, been a ford it'l probably last all of a few week so it wont matter.
It looks to me like the bearing case isn't metal in which case it won't need any grease.
Old Apr 12, 2007 | 10:49 AM
SafeChav's Avatar
SafeChav
That didn't make a lot of sense to me The spline to so the shaft locks into the clutch plate, not to make anything easier.......
And the bearing is made of metal, a plastic one wouldnt last long once the engine & clutch gets hot
Old Apr 12, 2007 | 05:07 PM
I think he means that it will stop the shaft sticking to the clutch if it is greased ?
As safechav says use some proper grease, I put the grease into the splines then push the plate on and off a few dozen time then wipe away any excess, if you use proper grease it is anti fling anyway.
SPRAY WAX for motorcycle chains works better though!!
Old Apr 12, 2007 | 05:09 PM
SafeChav's Avatar
SafeChav
He just asks if it is required to lubricate it
Old Apr 12, 2007 | 08:11 PM
efiste2's Avatar
efiste2
would copper-slip do the job,
Old Apr 12, 2007 | 10:58 PM
SafeChav's Avatar
SafeChav
well a lot of people do use it but its become quite a common occurunce for the copper to get into the bearing race and then it just destroys itself, id urge you not to use it personally.
High temperature grease is what you want
Old Apr 13, 2007 | 02:23 PM
efiste2's Avatar
efiste2
yet again, great advice, thanks mate!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
