need a small block of alloy[ pic update]
10 cm x 2 cm x 3 cm.? can anybody supply me with this?i want to drill and tap it to fit aeroquip connection from the inlet manifold then pipes from the other side to map sensor ect.
Originally Posted by Stavros
Id love an alloy dart block if i could afford one!
Why do you need one though? Going mega power?
wd pro, the alloy block will have 4 holes drilled and tapped into it,so the feeds will still be seperate.
WARNING !!!!
Do NOT feed the map sensor from this.
Even though there is no flow, a failure of any of the pipes connected
causing a flow will make your engine run lean.
My advice is always run the map sensor with its own pipe the same length
as the original directly to the inlet manifold as the length affects ecu
response time and drivability.
Same goes for the fuel pressure regulator. !
Originally Posted by Electronic
WARNING !!!!
lloyd,
That exra length will be fine.
Nothing is guaranteed secure.
For example, if you run the boost guage off it you (wont use aeroquip for that anyway)
The pipe is disconnected for what ever reason, you now have an air flow.
This will fool the map sensor as you now have in effect a bleed valve on it !
steerfromdarear
28
Jan 29, 2016 06:14 PM
3dr cossie
11
Dec 21, 2015 03:38 PM
borboyous
Aug 22, 2015 11:17 AM
