efi conversion plate to run mfi 8 injector holes plz help
Mar 19, 2007 | 10:06 PM
2nite started fittin my head i have efi casting but have conversion plate to run mfi still but can convert at later date. Conversion plate from vulcan engeering has four hole for injectors but then linked to mfi has 4 more injectors so have bit of dilemma should i be tryin weld in some injectors i dont know need some advice please boys
Mar 20, 2007 | 11:04 PM
Can you try and explain a bit clearer please?
Mar 21, 2007 | 11:29 PM
have you got the plate the right way around
Mar 21, 2007 | 11:33 PM
Thats needs explaining a little better as said
Mar 21, 2007 | 11:52 PM
i think he has'nt removed the mfi plate that holds the mfi injectors between head and mfi manifold and he has bolted the efi conversion plate to it.
MFI setup
Head, plate that holds the mfi injectors then a inlet manifold
mfi to efi setup
Head, adaptor plate then efi inlet manifold
what i think he has done is
Head,plate that holds the mfi injectors, adaptor plate then to efi inlet. thus causing to have holes.
Mar 22, 2007 | 12:01 AM
If hes using an adaptor plate to allow fitement of MFi equipment to an EFI head, it should just be a case of putting the plate on the end, and thats it!
Mar 22, 2007 | 01:41 PM
series 1 inlet manifodl is all one piece and u cant take the injector plate off which u should b able to do to fit conversion plate dont worry boys im gettin custom plate made up now
Mar 22, 2007 | 01:59 PM
Grammer is a wonderful thing!
Mar 22, 2007 | 09:05 PM
Quote:
GRAMMAR
Mar 23, 2007 | 12:25 AM
I didnt say spilling!
Mar 23, 2007 | 12:41 AM
But you can't criticise someones Grammar when you spell the word wrong!
Thats just blatant irony
Mar 23, 2007 | 01:06 AM
dnt care at least u cn usly mk ooot wot i is trin 2 say!
Mar 23, 2007 | 01:40 AM
Mar 23, 2007 | 11:15 AM
and you complain on me SafeChav
Mar 23, 2007 | 12:41 PM
funny boys i did it in rush didnt read just did it
Mar 23, 2007 | 01:28 PM
Mar 23, 2007 | 03:13 PM
Mar 23, 2007 | 03:33 PM
You're more understandable than him and you're not even english
Mar 23, 2007 | 07:31 PM
SafeChav
shut up boy i write like i txt on my phone
Mar 23, 2007 | 07:39 PM
Mar 23, 2007 | 07:43 PM
sorry mate thought everythin was aimed at me
Mar 23, 2007 | 07:46 PM
no not at all lol
Took the piss out of Jimmy cos he tried to correct your GRAMMAR with a mis-spelt word
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
marky_g
Aug 15, 2015 10:43 AM
Roosie
Aug 13, 2015 09:38 AM
