TPS question
Now i was led to believe that 2wd tps were red and 4x4 were black and were listed as pf01 for 2wd and pf09 for 4x4, now i needed a 4x4 as my magenta saph is running L8 and had been run with a 4x4 tps with the two outer wires swaped, so i got a black tps sent down from Paul at NYRS and find it has pf01 stamped on it, i also have searched ebay to find a red one advertised as a pf09, wtf is going on, by the way this is in no way a dig at Paul as he genuinely thought the same as me and that they were colour identifyable.
Sorry to ramble on a bit
Steve.
Steve.
PassionFords Creator
Red was fitted at the factory. Both PF01 and 9 were red back then.
ALL weber Aftermarket are black.
Examples:
http://stores.ebay.co.uk/Motorsport-...QQftidZ2QQtZkm
Examples:
i was led to believe that red is 2wd and black 4wd didnt think number matters......
anyhow my car is running 4x4 management with a 2wd engine and the tickover is too high (unless i unplug the iscv)i was told that i need a 4x4 tps to cure this......
p.s. sorry to hijack your post!!!!!
Steve.
Examples:
Examples:
Steve.
Originally Posted by cossie4i
Hi Steve,
I run with a L8 and my pf09 is grey.
How is it running ?
Steve.
How is it running ?
Steve.
Steve.
You need to make sure that you follow the correct procedure for setup, else you will have all sorts of probs with your ICV
The base voltage needs to be less than 0.6 volts when at idle. MEasure with a voltmeter at the ecu plug end. I believe it is pins 30 an 17 to measure across, but dont quote me.
I have a sheet that tells you the Ford how to guide. PM me your email address and I will forward the manual to you
JJ
JJ
Originally Posted by Moonstone Steve
so when fitting is there as setup procedure i need to follow.
Steve.
Steve.
tps are exactly as stu says,ive a pf09 here if you get stuck.
JJ
JJ
Steve.
Steve.
tps are exactly as Stu says,ive a pf09 here if you get stuck.
, Paul is going to get me one out in the post tomorrow.Steve.
Originally Posted by NORTH YORKS RS SPARES
Sorry about that Steve
As they say , you learn summat every day
Will post another asap
Steve.
Originally Posted by Bosch-Man
Steve...to set the TPS up is just put it on turn it and let it spring into its position and then tighten screws..thats how i always done it!!!
Best is to set up with a multimeter if possible, else the above is second best.
Moonstone Steve - Dont have a PM yet matey - need your email address!
JJ
JJ he has a SECS moniter...providing that says 100% at full throttle..its fine
Idle is more critical than WOT when adjusting.
JJ
just put a tp09 on my motor...hey presto..instant tickover
whats one of them then?anything like a pf09?
