Diffrence between the RS1600i/S1 ARB
Can anyone tell me if there's any benifit from either anti roll bar set up as i have an RS1600i one
in my garage and aint sure if i should put that one on or just stick with my S1 one?
The RS1600i rollbar is said to be the better one, being used on the Motorsport car. The roll bar itself is thicker and supposed to be the best for handling, the tie bars mount up with rubber bushes (as opposed to the jointed tie bars on a S1) and the RSi item has a cast alloy cross member which is quite a bit lighter then the heavy cast steel s1 item
Another way of looking at it though.... extra weight means more traction!"
There is very little between the two so wouldn't bother if I was you. If the item on the S1 is damaged then fair enough. But there is no point in changing it for the sack of things.
Also the cast plate on the S1 will b stronger than the 1600i item
There is very little between the two so wouldn't bother if I was you. If the item on the S1 is damaged there fair enough. But there is no point in changing it for the sack of things.
Originally Posted by JesseT
The RS1600 tie bars are rose jointed as well, but the two tiny M8 bolts holding them and taking all the braking forces have always seemed scary to my eyes.
Oh and I have completely snapped 1 alloy cross member in 3 places in competition use, but it immediatly got replaced by another
So it must be beneficial I did have the S1 corner plates on my Mk4 Escort with bigger rose jointed tension struts but didnt transfer them over to the Mk3 car when I built it
came up a treat rekon i may get it powder coated im hopeing not to do many heavy landings.
smitsturbo Spot on see you saturday. Aint sure what im doing with the spare ARB as i have had someone on to me already about that dude
I will have to check the rosejoints and see what the stroy is.
Im thinking changeing it as i bought the RS1600i one a good few years back i had heard that the RS1600i one was a motorsport spec item which was suposely better and as my car is pritty muched striped down at the mo was consedring which one i should fit back to my car.
truffleshuffle
Sep 10, 2015 09:35 PM
saph in dorset
Aug 14, 2015 10:10 AM
