Quickest way to drop gearbox (ERST) ???
Old Sep 9, 2004 | 01:10 PM
Adam_BlackRS's Avatar
Adam_BlackRS
Ex Ford Man
Default Quickest way to drop gearbox (ERST) ???
As above, with the engine still in.
Thanks
Old Sep 9, 2004 | 01:13 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
underneath takes me 4hr with abs on axle stands
Spiky's Avatar
Spiky
pick up
drop
2 seconds surely??? or am i missing something????
Old Sep 9, 2004 | 01:14 PM
Ryan's Avatar
Ryan
4 hrs
can remove a box in about 45 mins
Rs Gus's Avatar
Rs Gus
Originally Posted by Spiky
pick up
drop
Old Sep 9, 2004 | 01:27 PM
dumped's Avatar
dumped
StevenRW and MrC dropped his in 11mins once - no ABS
Old Sep 9, 2004 | 01:39 PM
davie0146's Avatar
davie0146
1. cut bolts
2. use big hammer
3. go to pub job done!
option 2
ask some scousers 11seconds
Old Sep 9, 2004 | 02:11 PM
cossiecrew's Avatar
cossiecrew
i agree with spikey quickest way im sure
Old Sep 9, 2004 | 02:16 PM
CabrioTurbo's Avatar
CabrioTurbo
As ryan says it will take about 45 mins to an hour (if youve got an idea what your doing)
IMO the easiest way to get the box out is to
1) jack the fucker up as high as it will go and secure with something (pref axle stands although old wheels seem to do me fine )
2) remove starter motor and shit shield platefrom bellhousing.
3 remove clutch cable and spedo cable (and amal valve if there is one)
4) remove gear linkage.
5) remove the ring of bolts that hold the gearbox to the block
6) remove the 5 gearbox cradle bolts. (please not engine will be at a funny angle dont worry )
7) remove wishbone bit that bolts onto chassis (this wil allow you to remove the drive shafts without taking a load of other shit off!)
8) loosen anti roll bar bolts
9) remove drive shafts.
10)
get some one to push the top of the engine down while you (or other volunteer ) 'wiggles' the gearbox untill it falls down.
Job done.. good luck getting it back in
Old Sep 9, 2004 | 03:00 PM
Adam_BlackRS
Ex Ford Man
Is the engine ok to hang on that one engine mount ??
Old Sep 9, 2004 | 03:04 PM
adamS2RST's Avatar
adamS2RST
My old black one was ok, stayed that way for about a month too
Old Sep 9, 2004 | 03:06 PM
cossiecrew's Avatar
cossiecrew
not realy wouldnt leave it like that 4 to long
Old Sep 9, 2004 | 03:09 PM
sm's Avatar
sm
support the engine with a jack with a piece of wood on the sump, lower the jack and the gearbox should slide off then jack the engine back up till its straight, thats the way ive always done it
cheers kev
Old Sep 9, 2004 | 03:10 PM
CabrioTurbo
' it'll be fine ' never done any harm to mine yet (not that i know of anyway ) it is by far the quickest/simplest way of getting the box out
mjonathan24
Oct 29, 2015 10:39 PM
Mc5506
Oct 5, 2015 09:57 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
