WTF does the power steering pressure switch do?
Old Sep 8, 2004 | 06:25 PM
Paul J's Avatar
Paul J
Default WTF does the power steering pressure switch do?
Pretty sure there aint a warning lamp and it driven by the engine not electric motor so what does it do?
If it raise's engine RPM under load then changing ECU will have done away with this and made it redundant, yes?
Old Sep 8, 2004 | 06:39 PM
richm's Avatar
richm
Is this a small-turbo EEC4 car Paul? The PS pressure switch is normally fed into the ECU for idle speed control input. It is also used as an input during some test/diagnostic processes on the EEC4 ECU to perform some service tests.
If the EEC4 ECU is no longer fitted, then the switch will have no purpose AFAIK.
Rich
whitneyd's Avatar
whitneyd
Depends. Some ECUs have an input for this also.
Old Sep 8, 2004 | 06:48 PM
Paul J's Avatar
Paul J
Brilliant Rich , just as i thought. It was EEC4.
One other thing, if not running closed loop is the lamba required for anything else? I know it is prefferable but for the mean time just to keep it simple.
Old Sep 8, 2004 | 09:37 PM
richm's Avatar
richm
if it's running open loop, presumably you have no catalyst fitted? The lambda sensor is only there in conjunction with closed-loop fuel control, to keep the catalyst happy.
Old Sep 8, 2004 | 11:31 PM
Paul J's Avatar
Paul J
richm,
Nope
Off it comes then
JK12
33
Apr 26, 2021 12:09 PM
Dubs44
Sep 19, 2015 06:31 AM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
xrmalin
Sep 13, 2015 06:52 PM
