Breaking Zetec Turbo
Old Feb 3, 2007 | 10:42 AM
throttlebodiedzetecturbo's Avatar
Default Breaking Zetec Turbo
2.1 Zetec
Calibra Turbo Pistons
Farndon Steel Rods
Jamsport Spec Cylinder Head
REC Big Valves
HD Valve Springs
Piper Cams
Piper Pulleys
Spark Plug threads machined for RS turbo cossie plugs
All new gaskets and pumps on fresh build only been started Zero miles.
Looking for 3000 gpb for the engine
WRC Inconal exhaust manifold modified by Primary Designs to take a T3 Flange. comes with longer spark plug leads modified coil pack bracket and thermostat housing. 600gbp
Jenvey 45mm bodies with swedish plenum ready to bolt to zetec head. comes with siemens 660cc injectors throttle position sensor and charge air temp sensor, all linkage included. 650gbp
DTA ecu with race quality harness. as new 700Gbp
Stage 2 BC box with quaife atb never been used
700gbp
Pro alloy rad 150gbp
Pro alloy cooler needs the 2 180degree pipes to finish has the fans 180gbp
Gaz fully adjustable coilovers 250 mile from new 300gbp
full set of poly windows from plastics 4 performance with sliders and window rubbers 110gbp
2 cobra evolution seats in blue narrow bodied ones, one has had small repair to the one ear otherwise smart 350 gbp the pair.
2 sparco 4 point harness 3 inch shoulder and strap dated untill 2012 120 the pair.
11 gallon alloy fuel tank 1.5 litre swirl pot sytec pump facet pump mounting bracket and filter 350 the lot.
IMG]http://i8.photobucket.com/albums/a49/zetecturbo111/P8160003.jpg[/IMG]
LM1 and XD16 ait to fuel gauge with data logger never used brand new sensor. 200gbp
PM With oserious offers loads of other little bits and pieces not listed just ask questions.
If the engine does not go then will prob not sell any of it, if someone is interested in buying the complete car as a donor car to take bits from then make an offer
Old Feb 3, 2007 | 01:11 PM
Rick's Avatar
Rick
Nice bits
Why u breaking?
Old Feb 3, 2007 | 01:35 PM
just had enough mate
Old Feb 3, 2007 | 02:28 PM
gus's Avatar
gus
because his a plank
still cant believe that you are breaking it dude
Old Feb 3, 2007 | 05:31 PM
philcab's Avatar
philcab
PM
Old Feb 3, 2007 | 06:30 PM
gary scott's Avatar
gary scott
PM Sent.
Old Feb 3, 2007 | 07:09 PM
timturbo's Avatar
timturbo
What condition is rad in? will it fit series 1 rs?
Old Feb 4, 2007 | 03:49 PM
also have tarox 6 pots with 300 discs on the front
cossie rear 288mm disc conversion all good pads..
600gbp for the lot including all bolts ready to bolt on
Old Feb 5, 2007 | 12:34 PM
s1kid's Avatar
s1kid
Pm Sent
Old Feb 7, 2007 | 07:53 AM
every one should have pm's back
Old Feb 7, 2007 | 11:12 AM
s1kid's Avatar
s1kid
Could you try and send me a pm as theres nothing in the inbox.
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
