S1/S2 downpipes
Jus went to fit a mongoose exhaust and it seems the downpipe is hitting off the subframe and wont go far enough to line up with the turbo elbow
are S1 and S2 downpipes different?
Just thot actually, the back end of the exhaust was on the ground, so maybe it had to be hooked on before it would clear the subframe?
The arms off the boxes are part of the mounts, and then theres the anti roll bar kidney plates as people call them.
generally a subframe is a whole frame that bolts to car and holds the engine
I still can't get my head around what you were struggling with though lol
well it basically is a form of subframe so get it roon ye
anyway
the downpipe was hitting off the corner of the "kidney plate" as you call it, and thus wasnt allowing it to go forward enough to mate up with the turbo elbow!
problem = exhaust wasnt up on the mounts at the rear, as had it all in one piece under the car, so it was somehow stopping it from coming onto the turbo elbow at that angle, rectified by mounting the rubbers at the back - that help ure small brain
anyway
Originally Posted by SafeChav
Tony, its on, that was the problem
Think there was a bit of sarcasm in Tony's post
Oh yea, forgot I had to simplify it in the post above for a simpleton
Hey your the one having the troubles with it
Im sure everyone but me understood it seems the downpipe is hitting off the subframe even though your car hasn't got a subframe
Originally Posted by NUTS RuS
You had already told us 3 times Davvy
Not MY fault, it's that chav end winding me up with his corectness/dumbness, he'll be eating a fist if he keeps it up
Just ignore him Davvy hes a
Oh..............btw
Tony i don't even want to know HOW LONG that took you to do, let alone where you got the inspiration to create such a monstrosity
See the way my contribution doesnt line up perfectly?? Thats cos i spent about 5 mins on it tops then got bored
