putting power down
Old Jan 27, 2007 | 05:50 PM
lewis_lisa's Avatar
lewis_lisa
Default putting power down
when my car was last out i was having probs putting power down as all it wanted to do was spin i have the standard s2 box with a ap4 paddle and was wondering if there was anything i could do to stop so much spin
i expect there always to be a fair bit but just wanna help it
Old Jan 27, 2007 | 06:14 PM
fast_ford_uk's Avatar
fast_ford_uk
gripyer and wider tyres
Old Jan 27, 2007 | 06:32 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Turn the boost down!!
Alternatively spend Ł1000's on the suspension and you can enjoy a mild improvement.
Old Jan 27, 2007 | 06:44 PM
RapidRS's Avatar
RapidRS
Be a little lighter with your right foot perhaps?
Old Jan 27, 2007 | 06:45 PM
gambit's Avatar
gambit
Default geting the power down
get yourself an uprated box with a quaife a.t.b, i had this and it made a huge difference. Also as said above, get yourself some wider tyres and wheels.
Old Jan 27, 2007 | 06:51 PM
Linsay's Avatar
Linsay
As above
Decent tyres transformed mine is loads nicer to drive on my Toyo's, shame they're rubbish in the wet
Old Jan 27, 2007 | 06:54 PM
nigel b's Avatar
nigel b
atb and rosejoints work well
Old Jan 27, 2007 | 08:50 PM
Rick's Avatar
Rick
geometry makes a massive difference. Goodyear F1's prob the best tyre to use, - i run 215's. ATB's are good, but ŁŁŁ
Old Jan 27, 2007 | 09:41 PM
lewis_lisa's Avatar
lewis_lisa
got yokos at moment and there brand new i thought these would be good tyres
its not that i have a heavy right foot but when i want to use the power it comes with masses of spin
are uprated diffs expensive as i dont have much money to spend on 1
Old Jan 27, 2007 | 09:53 PM
JamboRS's Avatar
JamboRS
focus rs 1672
is it a genuine rs turbo box with lsd?u checked it?
mind the roads are very greasy this time of year,i can get my 306 d turbo to wheelspin in second with its beastly 90bhp(prob about 70 now as its 117k )
also the cars prob peakin in the 20psi range and as soon as it hits a certian rpm its gonna break traction you just need to learn how to feather it and control it when its on boost
Old Jan 28, 2007 | 08:17 AM
MJC's Avatar
MJC
With the right tyres etc you should be ok. What sort of power are you running. There could be a good possiblilty you don't have a genuine RS Turbo gearbox. Alot of RS have had them replaced in the past with XR3i jobbies etc.
I'm running about 200bhp with a quaiffe ATB diff and toyo R888's. Can't even get it to brake traction in 2nd still got rose jointed adjustable TCA's and front tie bars to fit yet
I'd highly recommend Goodyear Eagle F1's as an all round tyre and check your gearbox is the correct type with an LSD
Old Jan 28, 2007 | 11:00 AM
Wardy257's Avatar
Wardy257
Stiffen the rear suspension to reduce weight transfer.
Old Jan 28, 2007 | 02:19 PM
lewis_lisa's Avatar
lewis_lisa
as far as i know it is an rst gearbox but i did have it changed a while back and its not been the same its hard to get into gear sometimes and crunches bad i reverse, i have to put it into 4th then reverse or it wont go
the garage told me my clutch was worn but it didnt look worn to me
Old Jan 28, 2007 | 04:45 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
An ATB will not help you get traction in a straight line over the std LSD, only when cornering. A good adjustable geometery set up is the best bet.
Gadget
Aug 26, 2015 01:02 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
The Enigma
13
Aug 20, 2015 09:38 PM
IAN RS2k
Aug 18, 2015 07:51 PM
