boosting problems!
Old Jan 22, 2007 | 08:33 PM
r-s-turbo's Avatar
r-s-turbo
Default boosting problems!
my car has always felt slow but quite torquey but anyway i jus throt i need a new actuator cuz it doesnt have the put back in the seat factor i feel it shud have!
right well at the weekend i put a boost gauge in and i only hit 4psi in 1,2 gears 4-5 in 3, and 6 in 4 and 8 in 5th.
do i need a new amal valve?
Old Jan 22, 2007 | 08:34 PM
Mixja's Avatar
Mixja
420
if your amal valve clicks when you turn ignition on, its working... more likely a knackered actuator...
Old Jan 24, 2007 | 06:12 PM
fast_ford_uk's Avatar
fast_ford_uk
try screwing the actuator in half a turn (shorten the rod)
Old Jan 24, 2007 | 07:14 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Default Re: boosting problems!
sounds more like the penny sticking,not uncommon
take the actuator arm of the wastegate and see if it turns freely
Old Jan 24, 2007 | 07:54 PM
fast_ford_uk
what do u mean wen u say penny sticking?
Old Jan 24, 2007 | 08:07 PM
JamboRS's Avatar
JamboRS
focus rs 1672
inside the elbow theres a penny thats on the wastegate arm,it has been known for them to stick,penny usually comes loose and hits the outer wall of the elbow causing boost to be inconsistent,happened to my mates last year,took the elbow off and the penny was very lose,sometimes it would turn ok then depending how the penny was lying it would stick,just changed the elbow for a spare i had
Old Jan 24, 2007 | 08:13 PM
fast_ford_uk
ok cherz
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
