How long has your paddle clutch lasted??
Its just that my alcon 6 paddle has started to slip after 6,000 miles ish.
My saph about 400 bhp with normal use and the odd bit of hooning around.
Is this normal?
Is this normal?
Originally Posted by Kirbycossie
Oh and can you buy just the alcon plate and where from?
miles all depends on the driver tbh!
I bet you're using the standard Ford cover
. This is only rated to stage 1 power, so 6000miles is good considering
The Alcon drive plate is listed on my website, Alvyn is getting confused with the cost of the standard cover (which isn't worth a wank
With 500bhp / 2wd and launching etc, I used to get 10k out of my FULL Alcon clutch. Switching to 4x4 and hydraulic arrangement, I get in excess of 15k....
.The Alcon drive plate is listed on my website, Alvyn is getting confused with the cost of the standard cover (which isn't worth a wank
).With 500bhp / 2wd and launching etc, I used to get 10k out of my FULL Alcon clutch. Switching to 4x4 and hydraulic arrangement, I get in excess of 15k....
saff is working!!!...atm
and i drive like an idiot....
i have an AP 6 paddle with ford cover on my car, works fine @ 450 BHP but dose slip if i launch hard more than 10 times with the anti lag on !!!
but with it off its fine, i would prob say that 450 is the limit of a ford cover and AP 6
not sure on mileage , done prob near 3k with only ALS abuse prob.....
going full AP and hydraulic clutch soon to be safe.....
i would say 6K is a bit soon really, get a full kit, skim the flywheel and fit a new cable. if you still have probs go hydraulic.....
The Alcon drive plate is listed on my website, Alvyn is getting confused with the cost of the standard cover (which isn't worth a wank :cry: ).
NO I aint he asked can you buy the plate on it's own
NOT THE COVER
and standard cover can work WELL with the 6 plate and it gives a lighter pedal(for road use) so it's NOT THE ON/OFF FEELING that you get using the full set up!
Those that have no problems, it may be that yopu have the old Ford cover, which was made by AP Borg & Beck and was fine to 400bhp
. Unfortunately in Ford's infinite cost-cutting wisdom, they switched supplier to some shonky Sachs arrangement, which is totally rubbish
Alvyn,
You can buy the Alcon paddle on it's own, but it is certainley more than the oner you quoted, hence why I thought you were getting confused
.Alvyn,
Just to clear it up. I have a full alcon clutch. Drives much nicer than previous 4 paddle. just slips a bit!
The following procedue MUST be followed to ensure longevity of clutch:
1. Brand new clutch cable fitted (as these stretch with age and so won't disengage the clutch fully, causing the clutch to drag and wear prematurely).
2. Flywheel surface ground (if not, it will have raised hot-spots on that will drag on the clutch and cause same issues as above).
mine lasted 8k, but was 2nd and had it re padded at ap aswell before i fitted
carnt complain as i was given it
and my car got driven hard, also scrapped my flywheel aswell though
due to launches
Mike Rainbird
i have a brand new alcon kit sat here i bought a few years ago off pj motorsport, how can i tell which cover i hae asi dont want the std one
so may have to buy a clutch cover
due to launches Mike Rainbird
due to launches
Mike Rainbird
due to launches
Mike Rainbird
.the box is just a alcon brake components box
teh cover just says made in england with a etched number but no ap any where
and the description on the box just says cos cover?
carnt read the part number as its ripped off but sure it says 0.50 cover plate
take it im going to have to bu a proper one then
Originally Posted by Billabong
For those not getting reasonable miles, forget about how hard you drive it - how do you drive in slow moving traffic - plenty of handbrake use, or do you ride the clutch?
i've always used the clutch in a on off manor and it seems to have been alright (touch wood)...the box is out at the moment and after 12-13k ish the clutch still has miles left...how long ?????
i use a Helix,
over 6k miles old, and 450ish bhp.
a few easy launches, sprints and quite a few track days..
Did slip @ brunters for a day, but was due to quadrant/rachet playing up, and since made my own clutch arm/quadrant. And has been fine since.
Always fit a new/good cable heat wrapped, and new quadrant/rachet.
(best part of 2 hours max and £35),
Or fit a hydrolic conversion,
