hid light kit problems
Old Jan 4, 2007 | 09:53 AM
les3002's Avatar
les3002
Default hid light kit problems
hi i seem to have a problem with my hid kit, they were excellent very bright when first fitted but they seem to get dimmer each time they are used to the point that now i would say my old halogen lights were better, is there a way of fixing this or is it knackered?
cheers les.
Old Jan 4, 2007 | 10:01 AM
Black_RS's Avatar
Black_RS
Is it a 'proper' Ł200+ kit or a Ł75 jobbie from Ebay? How long have you had them? They should at least have 12months waranty if from a reputable supplier?
Old Jan 4, 2007 | 01:02 PM
les3002's Avatar
les3002
they are from ebay same kit as what others on here have used without problems, been on the car for around a month maybe a bit less
Old Jan 4, 2007 | 01:43 PM
lazy_arse_pie's Avatar
lazy_arse_pie
shure your headlights aint dirty
was you at southport last night in the cav turbo ?
Old Jan 4, 2007 | 02:08 PM
EssexBoyRacer's Avatar
EssexBoyRacer
The balasts are probably faulty.
If you cant get anything replaced by the person you bought them from give these guys a try. www.hids4u.co.uk I usually deal with a guy called ian (via email). he's really friendly and they will help you with replacement parts to fit what you've already got (you wont have to buy a complete kit again.)
Old Jan 4, 2007 | 02:19 PM
D19 STE's Avatar
D19 STE
Do these kits need to be professionally fitted or can you order the kit and fit it yourself
Old Jan 4, 2007 | 02:21 PM
SapphyMike's Avatar
SapphyMike
you can fit them yourself.
Old Jan 4, 2007 | 02:24 PM
D19 STE's Avatar
D19 STE
Old Jan 4, 2007 | 05:49 PM
les3002's Avatar
les3002
thanks guys , im having some contact with the seller, although i paid via paypal do you think i could put a claim in for faulty goods seeing as im going to have to pay for new ballasts/bulbs? also he has his location as usa but when i recieved them they were from china
Old Jan 4, 2007 | 06:24 PM
the original's Avatar
the original
do you have the ebay link to the kit you bought please
Old Jan 4, 2007 | 09:13 PM
foreigneRS's Avatar
foreigneRS
Testing the future
that is why i would always buy from a uk based seller like hud4u, even though they are more expensive
Old Jan 4, 2007 | 10:31 PM
les3002's Avatar
les3002
heres the link:
Clicky
Old Jan 4, 2007 | 10:33 PM
Rick's Avatar
Rick
ballasts
Old Jan 5, 2007 | 12:11 AM
les3002's Avatar
les3002
both going at the same time and same rate does seem a bit strange though, im going to check the input voltage tomorrow and see if wiring it direct from battery and/or a better earth connection helps.
Old Jan 5, 2007 | 12:26 AM
SS1's Avatar
SS1
are the usable with morette head lights ..
i quite like the lighting they provide.
rather than the shonky usual ones
Old Jan 5, 2007 | 05:42 AM
Smit's Avatar
Smit
The 60ft Launch King
Check the wiring! As a shite feed will not power the ballasts very well
avid-fan - Yes they can be used with twin headlights
Old Jan 5, 2007 | 07:15 AM
les3002's Avatar
les3002
going to do that today smit and use a relay if needed, also it looks as it hid4u wont supply parts for cheap kits anymore as they have had so many problems with them but instead they offer a Ł70 trade in.
was thinking though if the kit was so crap what would they want with them?
Old Jan 5, 2007 | 08:46 AM
DaveEscos's Avatar
DaveEscos
Originally Posted by les3002
heres the link:
Clicky
there lies your problem!
they are fucking shite and cheap!
you get what you pay for!
Old Jan 5, 2007 | 10:09 AM
les3002's Avatar
les3002
thanks for that dave
Old Jan 5, 2007 | 10:15 AM
DaveEscos's Avatar
DaveEscos
well its true
an HID kit for Ł80!?
just ONE of my hid BULBS is more than than double Ł80
Old Jan 5, 2007 | 11:31 AM
NathR's Avatar
NathR
Great, I've just bought a set!
Old Jan 5, 2007 | 11:39 AM
Kev.H's Avatar
Kev.H
oh dear
I remember Dave buying a set for his cossie im sure they whre loads of bosh
Old Jan 5, 2007 | 11:51 AM
DaveEscos's Avatar
DaveEscos
The Kit on my cossie was Ł400
a Hi/Low kit. Was 100% apart from one bulb going down
Old Jan 5, 2007 | 12:35 PM
THEDMAN's Avatar
THEDMAN
oops..........
Old Jan 5, 2007 | 12:48 PM
RichieST's Avatar
RichieST
I have a set from hids4u, used them on my old focus, and were bloody brilliant. Put them over into my new shape mondeo, and after beefing up the fuses, they flicker about 10 times when switching them on. I did email some bloke from hids4u, but i found him pretty unhelpful!
I'm sure a direct feed from the battery should sort them out tho
Old Jan 5, 2007 | 01:46 PM
EssexBoyRacer
I've fitted a hi/low H4 set to my saph and the H7 kit to 2 x mk2 mondeos all from hids4u and they've all been fine.
Had to fit higher rating fuses on the mondeos though as they would blow on startup (same as jungleistmassiv)
Mine also flicker too if I have them on while starting the engine. But at any other time they are fine.
Old Jan 5, 2007 | 01:55 PM
NathR's Avatar
NathR
At least a few peeps have had the kit I've ordered with no problems. Does come with a 3 year warranty too, and at the price you really can't complain.
Seems strange to me that hids4u will buy these 'cheap' kits back I must say, they can't be that bad.
Old Jan 5, 2007 | 02:02 PM
Fil's Avatar
Fil
ELASTIC BAND
Default Re: hid light kit problems
cheers les.
ballasts, and the seller you got them from
12 months no hassle warranty on bulbs and ballasts
you might be lucky
Old Jan 5, 2007 | 04:20 PM
les3002's Avatar
les3002
lol i hope so, still a pita sending them back to hong kong etc
its definately the kit though i tested the voltage today with the engine running ive got a battery voltage of 14.7V and the voltage at the hid kit connection was 14.5V so no problem there i did try with a direct feed to the battery and direct earth but didnt make any difference.
also the guy on ebay has 100% feedback and lots of it so i thought i would be ok.
Old Jan 5, 2007 | 05:55 PM
Smit's Avatar
Smit
checked the earth?
Old Jan 5, 2007 | 11:05 PM
foreigneRS's Avatar
foreigneRS
Testing the future
yep, it's still round
Old Jan 6, 2007 | 03:05 PM
les3002's Avatar
les3002
yep put a direct earth aswell but didnt make a difference, plus with them working spot on when first fitted i cant see the wiring being at fault.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
YODI
Aug 30, 2015 01:12 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
