fooking head lights
my headlights in my saff 4x4 stopped working
replaced the bulbs and also noticed there was a 20a fuse in there so swapped that for a 10a one
still dont work, they did come on for a brief second
is there anything else i can check on it? or is it a job for the auto-electricans now
Originally Posted by lawnsy
the ltlle relay things thats what it was on our lasses rs turbo little brown ones..........
thats if the saffs have them....
yep the switch works, if can switch the light lights on then when you try putting main beam on they get even dimmer than the side lights (only 1, the other doesn't come on at all)
and the high beam work fine
help
help
help
help
My car has some sort of similar problem, it keeps shorting and melting the wiring loom that connects to the stalks on the steering colum, its done it three times, 1st time only a little puff of smoke and i ignored it, 2nd time there was big damage to this part of the loom and had to get this section of loom out of the breakers to do a transplant, 3rd and last time only two wires were damaged, auto sparkie has done another repair but now i too have no head lights
Can anybody shed any light?
Luciano
Luciano
help
help
Luciano
Luciano
can someone with proper working lights give some readings as to what sort of power should be going through them wires?
Originally Posted by paulpalmer
That isn't what mine was doing. On sidelights do your dipped beam bulbs illuminate?
i think they do but will double check 2nite, what does that tell you if they do?
so we reckon it could be the brown relay in the fuse box?
nice one getting a bit closer now
cheers
cheers
Dont know if it helps, but my earths for the lights were complete gash, and they packed up completely.
Try taking a good earth point with fresh wire, and connecting directly to the earth of the lights - this will tell you if it is a bad earth.
9 out of 10 times, Ford wiring failures relate to bad earths.
JJ
JJ
JJ
JJ
are the lights on a looped circuit? do they share an earth? as they are both not working
The problem I had with my headlights was down to an earth fault. I had no dipped beam, no main beam (but I could flash it) and no washers and all of that was due to an earth from the switch being missing somewhere. We added a new earth to one of the pins and everything came back.
I had sidelights, dash lights etc though.
cheers bud
so wheres the earth for the headlights?!??
willit be one of the wires coming direct from the headlights i need to look at first of the actual switch by the steering wheel
cheers again paul
just been trying to figure it out now, this brown relay is it the small one in the top right corner of the fuse box? thats the only brown one in the fuse box
this is doing my tits in now
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
