What turbo to go for (saff 4x4)
Old Dec 28, 2006 | 11:20 PM
Tonks's Avatar
Tonks
Default What turbo to go for (saff 4x4)
Currently ive got my head away at NMS having a stage 1/low lag head done.
Myself and bud-wies are then going to rebuild the bottom end (probably retaining standard spec)..
when all done I was going to bolt my current old faithfull t34.48 but tbh it seems a bit of a waste.
So i was thinking of a bigger turbo to run as im ditching the 803's for some 403's. where am i best to get a bigger turbo from and what is the cost / bhp i can expect.
Would a t38 be the way to go as i would like something a bt different from a t34?
regards Jamie
Old Dec 28, 2006 | 11:21 PM
rapidcossie's Avatar
rapidcossie
t34/63 or t38...
depends what power you want?
Old Dec 28, 2006 | 11:22 PM
Stu.H's Avatar
Stu.H
gt30
Old Dec 28, 2006 | 11:24 PM
Doug's Avatar
Doug
As Rapid sais unless you go maram anti lag t4 stay with either t38 or go gt35 roller to get best combo !
Regards Doug .
Old Dec 28, 2006 | 11:25 PM
radiant red's Avatar
radiant red
Im thinking about a GT30 upgrade,do they all require external wastegates??
Old Dec 28, 2006 | 11:26 PM
Tonks's Avatar
Tonks
What sort of power can i run on them without pushing them beyond there limit whilst using 403's.
Also what sort of cost do they command
Thanks Jamie
Old Dec 28, 2006 | 11:33 PM
Doug's Avatar
Doug
either set up t4 maram anti or GT35 roller you should see close on 500 hp with the correct map and correct internals and injectors without pushing either turbo to the limit !
Regards Doug .
Old Dec 29, 2006 | 12:00 AM
Danny @ Enhanced Performance's Avatar
if your only running 4 greys i wouldnt go bigger than the t38 the t4 would always want more and a gt35 is way more than you need you would defo need 8 injectors or big cc injectors for that
Old Dec 29, 2006 | 05:43 AM
bud-weis's Avatar
bud-weis
Football Cwazy
You really need to decide on a spec asap mate
if we know what were aiming for then it can be built right first time and won't have to come apart in the future!
Do consider your transmission though,400bhp will kill standard 4x4,450bhp will kill even uprated stuff.......for over 450bhp you really need the whole transmission done with thick wall diffs etc.
if i were you i'd try to get a ride in Ad's cossie and see if that feels fast enough for you....if it is then go for the T34.55 from turbotechnics. if it's not then a T38 or a small NMS spec GT30 would be best (Karl has his own spec GT30's now that would be ideal for your car i reckon,but i think they are a little dear)
another thing to add to that price i gave you is the cost of a WRC gasket,Grp A won't be enough for anything bigger than a T34 for a very long time.....
As i say,either a power figure or how you'd like it to drive then we can go from there.....you may need more work done to the head too at this rate including new cams
Old Dec 29, 2006 | 05:53 AM
bud-weis's Avatar
bud-weis
Football Cwazy
oh and a new clutch
and i dare say a few other things i haven't thought of just yet starts getting pricey at this level mate
Old Dec 29, 2006 | 09:05 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
universal t38...same lag as a t34.63....but more power
Old Dec 29, 2006 | 09:09 AM
Mr Brannen's Avatar
Mr Brannen
good thread
Old Dec 29, 2006 | 09:36 AM
SapphyMike's Avatar
SapphyMike
depends on head spec, cam spec etc.
chasing big numbers is ok if you arent bothered about low end stuff.
personally, the head spec you have, std c/r possible (unless advised otherwise) and either a T38 (as long as the head / cams are ok to use with a T38) or a T34.63 would be nice and punchy.
Old Dec 29, 2006 | 10:39 AM
Tarren's Avatar
Tarren
Good thread this keep the comments coming
Old Dec 29, 2006 | 05:25 PM
col cos1's Avatar
col cos1
i run 4 greys and t4 hybrid with no fueling probs
Old Dec 29, 2006 | 05:31 PM
T88H, maram shaft, and anti lag
Old Jan 2, 2007 | 11:53 PM
Jim Green's Avatar
Jim Green
Mmmm, Where do I start.......
Anything over 350bhp and it's starting to get expensive.....IF YOU WANT IT TO LAST, AND USE THE POWER REGULARLY.
Think Mountune WRC Head Gasket at 360 quid + Vat
Think Injectors.....Gray's at Least.
Head Work..... I paid 2k for this.
Cams, and don't forget, depending on what drivability you want, depends on what cam you want....leading to the possibility of having to have pocketed pistons.....and if you've gone that for, you might as well have low compressions ones as well.
Then of course the standard Intercooler will be totally useless, as will the mapping, so now you've reached about 5k, and you've still a long way to go.
T34 : Low Lag, Good Mid Range Power, Drops off at much above 6k, and on it's last legs at 330bhp.....Will produce it, but for how long.
T38 (Universal Turbos) Very Similar Characteristics to T34, but will continue to produce boost to 7k and over. Proven to give 430bhp with the correct other parts.....Head, Cams, Comp Ratio, Ancillaries, Intercoolers etc.
T38 (Turbo Technics) Again, Similar Characteristics, (Slightly later pic up)....but keeps going even further up the rpm range.....but do you want a good torquey engine ....... or a screamer.......and which will last the longest and be the most driver friendly on everday roads.
T4 I feel controversy coming by the truck load. But my opinion only ...............Best place for a T4 is in the Bin.
Anyone can build a 400bhp cossie engine, but it's building one that lasts.
Old Jan 3, 2007 | 12:25 AM
stevieturbo's Avatar
stevieturbo
C**t
Get with the times....go for a proper BB turbo.
AE Turbos do a few internal wastegate bolt on jobbies, based around a GT30 core.
Old Jan 3, 2007 | 10:59 PM
radiant red
any idea how much these are???
Old Jan 3, 2007 | 11:04 PM
stevieturbo
C**t
Depends on spec....
Circa £1100+vat to about £1300+ vat I think...
It was a few months ago I got prices.
Old Jan 3, 2007 | 11:11 PM
radiant red
something im seriously considering,there round the corner so ill give them a try.
wonder if reyland can supply....
Matt Baxter
Sep 16, 2015 08:30 PM
frug
Aug 26, 2015 06:46 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
IAN RS2k
Aug 18, 2015 07:51 PM
