FORD 6000 CD PROBLEM!!!
Old Dec 27, 2006 | 08:08 PM
mercury grey minter's Avatar
mercury grey minter
Default FORD 6000 CD PROBLEM!!!
The wife,s 02 plate focus 6000 CD PLAYER won,t play the CD,S.They go in but when you press PLAY.It said.... CD ERROR. and when you EJECT it.It said NO DISC.Is it a common problem and is it worth getting it fixed or just get another one of E-BAY for £75.??
Old Dec 27, 2006 | 08:39 PM
JamesH's Avatar
JamesH
Try a CD lens cleaner you can get them loads of places only a few £'s at the most, and will most probably cure it
Old Dec 27, 2006 | 08:41 PM
TrevCos's Avatar
TrevCos
Exactly the same thing happened to me on mine in my Focus mate. The CD's sometimes jam. Take the unit out and and remove the CD's from the unit, as I remember the trays are all on a spindle and you need to just gently move them up as far as they'll go so you can get the CDs out manually. It is possible to do although the last ones will be tight, but like I say take your time and be gentle. Then make sure that all the CD trays are back down where they started, bolt it back together and put it back in the car. All should then be well.
Old Dec 27, 2006 | 08:42 PM
dave green's Avatar
dave green
Getting a nother one would proberly be the cheapest.
dave
Old Dec 27, 2006 | 08:43 PM
TrevCos's Avatar
TrevCos
Not with one of those mate, they're bloody expensive new. There's always E-BAY I suppose but then again you still don't know what you're getting. It's an easy enough fix if you're confident enough to take the top off.
We are talking the multi-disc one aren't we mate?
Old Dec 27, 2006 | 08:47 PM
mercury grey minter
Its not the multi disc one .It,s the single c.d one.
Old Dec 27, 2006 | 08:48 PM
TrevCos's Avatar
TrevCos
Oh right, can't help there then, big hammer I reckon!
ps If you are buying another one the multi-disc ones are brilliant! I commute a lot and it's great for that. I've only had that problem with it once and it's never done it again.
Old Dec 27, 2006 | 08:49 PM
mercury grey minter
Not a common problem then.
Old Dec 27, 2006 | 08:53 PM
TrevCos's Avatar
TrevCos
What Smidsy said might sort it, worth a go anyway.
Old Dec 27, 2006 | 08:59 PM
mercury grey minter
Lense CD cleaner it is then.
Old Dec 28, 2006 | 07:31 PM
mercury grey minter
Had another look at it today and it flashes a fault code ..E11.........ANYONE.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
nick8saff
Aug 16, 2015 05:35 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
