fuel pump wiring
Old Dec 18, 2006 | 09:03 PM
vodoo1's Avatar
vodoo1
Default fuel pump wiring
long story but a mate of mine helped me wire in my rst loom to my mk5 escort , he ran the fuel pump relay power wire direct off a 80 amp auxilary fuse on the battery sooooo - would running a live wire from the battery direct to the fuel relay cause it to burn the relay and fuel pump out ??? it also wasnt fused , it should be a 20a fuse ( which it is now )
just to clarify it went -
battery - fuel pump relay - fuel pump
it now goes -
ignition switch - 20a in line fuse - fuel pump relay - fuel pump
Old Dec 18, 2006 | 09:57 PM
Wardy257's Avatar
Wardy257
You current system looks fine. A fuel pump only draws 4 amps in normal situations.
JK12
33
Apr 26, 2021 12:09 PM
jonjg
Sep 1, 2015 03:46 PM
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
