Actuator - turning boost down
Old Dec 9, 2006 | 08:28 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Default Actuator - turning boost down
First of all my car was setup standard with 7psi boost, all was fine till one day it started hitting 11psi (never touched a thing)
amal valve etc all plugged in, std piping. .
ONLY things I can think of is, when fitting the turbo, I sat it on grass and the actuator dug into the dirt and filled the hole where the pipe goes on, Im sure I pushed it all in tho. . could this of blocked a pipe (so to make it run 7psi) then un-blocked it with the pressures and now its running more boost?
the thin hoses from amal valve-metering unit/turbo etc. . couple of them aint exactly tight fits with the original clips, done a couple (the ones I could get to easily) with small jubilee clips but still some that aint on tight.
or any other things that could make it run more boost? im pretty sure it's got a -31 but not 100%
Now, what im wondering is after I fix the hose clamps and it still does it, if I turn my actuator to lower the boost, would that be ok? as I cant for the life of me work out why its overboosting.
If so, what way do I turn it, and what will it lower it by one turn? if I can get it to 7psi that'd be great.
cheers.
Old Dec 10, 2006 | 04:14 PM
vroooom ptssssh
It Wasnt Me!
Somebody must know what an actuator is
Old Dec 10, 2006 | 06:26 PM
turboloon's Avatar
turboloon
Default accuator
i think you need to lenthen the rod(screw it out) to reduce the boost!!! iwas the car noticbly diffrent running higher boost?
Old Dec 10, 2006 | 07:54 PM
khanny's Avatar
khanny
CHECK THIS WILL EXPLAIN ALL http://bbs.rsownersclub.co.uk/showth...s+buying+guide
Old Dec 10, 2006 | 09:36 PM
vroooom ptssssh
It Wasnt Me!
turboloon, thanks & Im not sure tbh. . I thinkso, but you know yourself if it's not running right you dont wanna tempt fate and boot it
khanny, cheers
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
jay030787
Sep 18, 2015 04:38 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
