saff cossie over fueling
Old Nov 20, 2006 | 04:15 PM
Cawood's Avatar
Cawood
Default saff cossie over fueling
having a few probs my my cossie at the mo
it keeps overfueling, done it 3 times now in about 3 weeks
was just sat there in it last nite with the engine ticking over then it died and wouldn't start again, you have to leave it about 30min til it starts again
had a new fuel pump fitted n the wiring re done about a month ago, and a full set up if that could be anything to do with it?
any ideas
Old Nov 20, 2006 | 04:18 PM
Eagle's Avatar
Eagle
Super Moderator
is it a 4wd??
Old Nov 20, 2006 | 04:19 PM
Cawood's Avatar
Cawood
yep
Old Nov 20, 2006 | 04:23 PM
Eagle's Avatar
Eagle
Super Moderator
3 multi loom plugs over the back of the engine bay ...
i can bet if they have not been sorted out its due to one of them .. they are a real pain in the arse .... either that or map sensor
mine will be done ready for next year ...
easiest way is to pull the connections apart and use a good switch lubricant on them .. not wd40 tho .. just push em in and out a few times ...
Old Nov 20, 2006 | 04:26 PM
Cawood's Avatar
Cawood
ahh bugger! know what you mean but dont have them anymore
they've been chopped out and rewired
just had all that lot sorted @ tuners as it was a bit of a mess
Old Nov 20, 2006 | 04:27 PM
Eagle's Avatar
Eagle
Super Moderator
so .. possible map sensor .. im guessing now .. only cos mine was diagnosed with the exact same problem .. sat there all happy like .. then just turned itself off .. wouldnt restart and stank of fuel ...
Old Nov 20, 2006 | 04:29 PM
Cawood's Avatar
Cawood
ditto
know if it can cause damage to the engine? if i still run the car?
Old Nov 20, 2006 | 04:45 PM
charlie luciano's Avatar
charlie luciano
[quote="Cawood
know if it can cause damage to the engine? if i still run the car?[/quote]
Engine can blow up if you get bore wash
Luciano
Old Nov 20, 2006 | 09:46 PM
Tangodeltasierra3's Avatar
Tangodeltasierra3
Water temp sensor ? I seem to remember my saff 4x4 doing similiar but it was a few years since now.
Old Nov 21, 2006 | 08:30 AM
Cawood's Avatar
Cawood
[quote=charlie luciano]
Luciano
fuck, best get back on the phone to NMS
Old Nov 21, 2006 | 08:35 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
As has been mentioned, if the (blue) water temp sensor that feeds the ECU fails, it thinks it is -52°C and runs permanent cold enrichment to compensate .
Old Nov 21, 2006 | 10:35 AM
STUCOS's Avatar
STUCOS
Mike will secs monitor help find the fault,as my 3dr has a similer fault
cheeRS stu
Old Nov 21, 2006 | 11:04 AM
Cawood's Avatar
Cawood
thanks for input lads
are there any checks or repairs i can do myself?
also as its an intermittant fault will any tests/fault diagnostics show up any faults when it seems to be running fine?
cos as i say its only done this 3 times now in about 3/4 weeks (n the car is my daily drive)
Mike Rainbird
Caraholic
If it is one of the sensors that is monitored, then yes it would (such as TPS, water temp, MAP sensor, battery voltage) .
Old Nov 21, 2006 | 11:12 AM
Cawood's Avatar
Cawood
mike, can i pick ya brains
whats this water temp sensor look like & wheres it situated?
whats involved in replacing it?
Old Nov 21, 2006 | 11:30 AM
Mike Rainbird
Caraholic
Back of the head and it's a bitch to get to on 4x4s .
Looks like this:
http://cosworth.info/store/view_prod...p?product=1048
Old Nov 21, 2006 | 12:15 PM
Cawood's Avatar
Cawood
Looks like this:
fuck, so will be quite hard then with my big shovel hands
hows it fitted? can i just replace it and job done? or is some sort of set up need?
cheers mike
Old Nov 21, 2006 | 01:20 PM
rabmc's Avatar
rabmc
Id say map sensor
Old Nov 21, 2006 | 01:24 PM
Dicko&Vacant's Avatar
Dicko&Vacant
mine did exactly the same and was my map sensor
Old Nov 21, 2006 | 01:27 PM
Mike Rainbird
Caraholic
Just unscrews and is a direct replacement. HOWEVER, I have know it to be the wires that fracture where they go into the plug when disturbed and not actually the sensor itself....
Old Nov 21, 2006 | 02:10 PM
Cawood's Avatar
Cawood
nice one! thanks for the help mike, i'll check the wiring out as well
cheers rab/dicko
regarding the map sensor - can that just be replaced as well?
Old Nov 21, 2006 | 02:20 PM
Mike Rainbird
Caraholic
cheers rab/dicko
Yes it can .
Old Nov 21, 2006 | 02:31 PM
Cawood's Avatar
Cawood
topman cheers mike
Old Nov 22, 2006 | 08:24 AM
Cawood's Avatar
Cawood
sorry bttt need to ask another question
also when first starting it up in a morning it idles high (1500-2000rpm) and fluctuates, is this anything to do with it?
and is there a way of testing the water temp sensor to see if its failed?
cheers lads
Old Nov 22, 2006 | 09:08 AM
Eagle's Avatar
Eagle
Super Moderator
water temp sensor is a complete pig of a job .. whoever designed it there needs a good kicking i did mine from underneath... but its not fun..
Old Nov 22, 2006 | 10:37 AM
Cawood's Avatar
Cawood
i can see it now.... i'll start there for half hour staring at it then think fuck it i cant be arsed it looks like a blag
cheers lads
anyone? rainbum?
Old Nov 22, 2006 | 11:05 AM
SapphyMike's Avatar
SapphyMike
cheers lads
anyone? rainbum?
could be the idle speed control valve.
unplug it next time and see if it idles ok.
Old Nov 22, 2006 | 11:54 AM
Eagle's Avatar
Eagle
Super Moderator
if you feel down between the head and the oil dipstick you will find it ..
make sure it dont wiggle and the cap is on properly
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
Adam-M
Aug 26, 2015 05:53 PM
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
