Slight Problem With Cossie
Old Nov 19, 2006 | 11:36 PM
llw's Avatar
llw
Default Slight Problem With Cossie
Right my 4x4 cossie seems to have a slight splutter/holding back when flooring it in 1st gear
sometimes its ok sometimes its not , its fine in all the other gears
im gonna change the plugs on it tomorrow anyone know what plugs are best its stage 1
also the rev meter is always jumpin about, never stays where its suppose to
any ideas
all feedback shall be appreciated
Old Nov 20, 2006 | 07:12 AM
Harris.'s Avatar
Harris.
I use PP8'S in the 3 door and 4x4 !!
Old Nov 20, 2006 | 09:06 AM
TurboShed's Avatar
TurboShed
Cossiemodo
It's odd that it's only in 1st gear, but I guess then it's load related. Maybe it's present in other gears, but only noticeable in 1st?? Just some thoughts
Old Nov 20, 2006 | 11:58 AM
Smoker's Avatar
Smoker
Default yogi bear!
check dizzy cap and rota
Old Nov 20, 2006 | 12:53 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Default Re: yogi bear!
Yep, cheap stuff first!
Old Nov 20, 2006 | 01:17 PM
llw's Avatar
llw
right gonna change the plugs dizzy cap, rotor arm
change the oil, oil filter etc
basically give her a service and take it from there
thanks
Old Nov 20, 2006 | 04:18 PM
bigad4x4's Avatar
bigad4x4
Get a check on the alternator just to eleminate it if everything else fails
Auto electrics by me check them for nowt and only takes 2 min
worth a try just try your local guy
CossieRich
30
Sep 8, 2015 10:08 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Archiejay
Aug 12, 2015 12:07 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
mattman1234
24
Aug 1, 2015 11:46 AM
