today my car got a new name...
skippy...
...the bush kangeroo
started kangerooing on the motorway at about 70ish stopped doin it after a few mins
it was fine on full throttle tho.
its occasionally hiccuped around town in traffic n stuff but i just put this down to it being the autobox ECU not liking the manual transmission, as all the 24vs ive been in have slight troubles with this kinda stuff...
but this kangerooing was a bit weird...
i'm thinkin funky TPS? as when i opened n closed the throttle a few times it seemed to clear it.
am i right in thinking its gonna be TPS, MAF, or MAP related
only problem is its all fine again now n drives perfect, so possibly intermittent fault? i figure its worth checking out tho just incase it comes back, as its a tad embarasing
the car's getting new plugs tomorrow regardless as theyve been in there for an unknown ammount of time, but i heard of sum1 who was having similar problems (his was all the time tho) n it was just his shitty old plugs
cossie1 no way am i changing the leads, theyre 200+quid for a set!
if im changing the plugs i wanna use some witha cooler range for the laughing gas... anyone know what std plugs are for the 24v? n could tell me what one grade cooler is?
also ill be gettin some from halfords ($$$!) so shall i got for the bosh super4s, copper ones, platinum ones, v electrode ones etc. etc. to me a plug is just a plug, ive always used std NGK ones or motorcraft ones
not what you want with trial n error tho
next time im round my mates ill swap my leads with his n see if his car has any problems
altho i wouldnt have thought it'd be plugs n leads coz its perfect on full throttle, n i thought that this is where you'd notice the ignition side breaking down...
i like your logic
anyone got microcat n facy looking up the price of a new TPS? mine's diret anyway so if its not expensive i'll swap it as its easier than cleaning mine
Burton Power do the leads for Ł20, you have to wait a while but they are good. Failing that, got mine same day from Motaquip for Ł27. The fookin Magnecore ones are only Ł100 - where the fook you get Ł200 from.
Plugs are a couple quid each from Ford, you want the slightly later ones with the screw on caps - check them at the service counter as some are shagged, you'll be able to tell straight away.
Check TPS with a multimeter on resistance, clean up all your multiplugs and grease connections, recheck everything again.
Don't discount the lambda sensors, my car was missing on part throttle cruise two weeks ago and one of the lambdas wasn't connected properly.
hey dont tell me about halfords shite, trust me it aint all good stuf that ya thinking
i work for the fooking pikey firm and i know the shite they sell
non of it is to do with quality but profits
as mark says
checkd TPS earlier... 0.9v to 4.6v and smoth all the way thru, and those readings are well within accepted limits...
also i left the battery unplugged for a while and then gave the car a learning session afterwards :P
didnt do the plugs earlier... fords+factors were closed n halfrauds didnt hve the right ones
put some new std ford plugs in there (well, 5 of em... lol need to get one of those deepreach sockets from halfrauds tomorrow to get at no4, mine's a gay twisty handled one) which were supposed to be pre-gapped but they all had ZERO gap (ie elctrodes rouching)
anyway, sorted that out
car idles a lot nicer, and seems to drive a lot smoother at low throttle openeings/low revs etc.
just gotta swap no4 plug tomorrow to finish the job off
anyway, sorted that outcar idles a lot nicer, and seems to drive a lot smoother at low throttle openeings/low revs etc.
Jim - bloody listen when people tell ya stuff!
Careful with that gay twisty handled socket, very very easy to cross thread the plugs putting them in
sean, they only had 6 in stock... and i know how to re-gap a spark plug
also i know wot u mean about crossthreding! i had to take SOOOO much care when putting the buggers back in, took fookin ages
i like your thinking
i once got handed a rocker cover gasket that was bent at 3 different angles..
"erm... mate... WHAT THE FUCK IS THAT?!?!"
i promptly received a nice straight looking gasket
i still remember the day some old lady came into halfords to buy a headgasket that her husband had ordered, and she folded it up n put it in her bag
kosienutter
31
Aug 22, 2015 09:55 AM
yawiejon
15
Aug 9, 2015 06:36 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
