the safest spec for 200bhp
next year my car is coming off the road and getting a full respray and more power what i basically want to know is how do i get 200bhp in a good solid safe all round package heres a sort of rough spec
engine
steel pistons?, steel conrods, -31 actuator, 5th injector setup, 2wd cossy intercooler, uprate plug leads, ahmed bayjoo chipped ecu, bleed valve and the k&n and mongoose already on the car, what else would the car need
transmission
stage 1 gearbox, and uprated clutch- what has been or is used and rough prices
suspension
uprate the shock and polybush everything
brakes
braided hoses, 2wd cossy front discs 4x4 calipers and 4x4 rear setup
wheels
standard
so would this make the car a safe 200bhp anyone thoughts, prices on the work etc wouldbe appreciated thank you
engine
transmission
suspension
brakes
wheels
standard
Originally Posted by scraggyrst
would a turbo off a cossy be useful as i think i hear people use erm.
yeah i am keeping mfi so pistons will be ok will the crank be ok aswell or do i need an uprated one
crank will be fine i had a cossie 4x4 turbo on mine with a modded .48 housing from a saab turbo
large front mount cooler
Induction kit,
1 bar boost,
-31,
chipped ecu (for boost)
quality exhaust system
waterinjection...
koni's with -30mm springs
cts stage 1 box
cossie breaks (or better)
organic clutch
strut brace
have a good tuner set it.......200 all day long safe as houses
Induction kit,
1 bar boost,
-31,
waterinjection...
cts stage 1 box
organic clutch
strut brace
well got some of your list already i got
filter k&n panel
mongoose straight through exhaust with 4" rolled out tip
ahmed bayjoo chipped ecu and -31 collins actuator which will go on, on the 25th by apt
getting all the pipework to use a 2wd intercooler, got the intercooler and reverse charge carrier just got to get straight piping, and 90' bend samcos, then when it comes off road for respray i'll fit it and get the engine checked rebuilt with steel rods, 4x4 turbo, cossy brakes
filter k&n panel
GRS/Pro Alloy/Pace Frount mounted Cooler
Stage 2 Turbo
Drilled Airbox
16 psi
Stage 1 box and Organic Clutch
Should all work nicely for 200 bhp at the Flywheel
As above and with low comp pistons and a Stage 2 head should see 200 bhp at the wheels with 20 psi
Stage 2 Turbo
Drilled Airbox
16 psi
mate of mine was running 201 bhp
Induction kit,
1 bar boost,
-31,
extra swirl pot
see 201bhp the the torque its well over 230
with a set up an jamsport on there rollers
oh on stradard breaks, box and on 15's
Induction kit,
1 bar boost,
-31,
extra swirl pot
to get a good reliable 200 brake think this recommended spec would be good :-
a full tune
upgraded chip & actuator
bigger intercooler or even a chargecooler
cone filter
exhaust
ht leads 8MM or above ( stds are crap )
plugs ( YQC57C )
fully worked head
cam-kit
clutche
at this spec the turbo & gearbox should be fine im sure theirs cars out there running 200+ on std turbos & boxs.
a full tune
cone filter
exhaust
plugs ( YQC57C )
fully worked head
cam-kit
clutche
I saw 205bhp with the following mods, and its seems to be bullet proof,
stage 3 big valve head
piper 285 cam
stage 2 h/b turbo, collins
some pistons that cost me £780
fifth inj
and a chip
I forgot about the
4" magnex
Pace intercooler
piper 285 cam
fifth inj
and a chip
I forgot about the
4" magnex
Pace intercooler
a full tune
cone filter
exhaust
plugs ( YQC57C )
fully worked head
cam-kit
clutche
a full tune
cone filter
exhaust
plugs ( YQC57C )
fully worked head
cam-kit
clutche
dont personally like champion plugs but each to their own and whoever sets it up will choose the plugs anyway
dont need a worked head for 200hp.
speak to NMS for advice as they have always been excellent for me
a full tune
cone filter
exhaust
plugs ( YQC57C )
fully worked head
cam-kit
clutche
a full tune
cone filter
exhaust
plugs ( YQC57C )
fully worked head
cam-kit
clutche
as i say there are plenty of ways to get somewhere and everyone has an opinion, just my 2p worth
IMO from what i have seen and been shown then you really have to be carefull of the fueling when porting the head as its not the best of our MFI cars
what do you mean how old are the leads? buy new ford ones for about £20
200bhp will not need major mods, forget all the bullshit pubtalk stuff,
start with the normal, chip, exhaust, air filter
bigger intercooler, half width will be ok
standard turbo is fine for 17psi
an up-rated cam will help but most of them these days wear out quickly
if your car has enough fuelling to hold the 17psi that should see around the 200bhp mark. if you want a bit more or it falls short of the 200 mark it may need more fuel, this is where a 5th injector is needed & maybe an up rated pump, couple this with a hybrid T3 turbo (stage 2) & you should sail over 200bhp & still have a car that is good to drive
£20
i mean the ford ht leads were designed 20 years ago what you saying thay gonna be better than say magnecor?? the ford leads dont provide proper & permanent RFI & EMI suppression to avoid interference to electronic management systems, ice etc also the std leads cant cope with high temps like these NEW UP TO DATE DESIGNED SILICONE RUBBER HT LEADS just my thoughts, you get what you pay.
£20
thanks for all the reply seems like their are more than one way to skin a cat!
well i'll talk to christain at apt when i feel like the time has come for more as "pops" says just get a cossy, and a 2wd cossy sounds very lush to me but 20, 2yr's ncd and no garage to park it in overnight i don't see it happening
If your still running mfi you may have to go low comp to raise the boost above a bar but im sure somone will correct me if im wrong.
