ignition advance etc....
Old Nov 6, 2006 | 03:32 PM
Westieboy's Avatar
Westieboy
Default ignition advance etc....
Hi All,
Just in the process of plonking in a new 2ltr cvh to my Westfield....A quick question on the ford electronic ignition set ups.
Any of you knowledgeable people out there know how the advance works on these (I'm running twin 40's, and the vacuum advance is disconnected)....The Dizzy is (I believe) a newer lucus version, and has the two bolt fixing....Do these use springs to set advance at higher rpm or weights?....Any advice on set up also appreciated (Car will have ported head and 280 (ish)duration cam - probably piper 285C.
Cheers.
Paul.
Benleys
Escort Range
Sep 28, 2015 01:56 PM
beller
Sep 21, 2015 04:13 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
