xr2i no rev?????
can some one please help i have a 8v cvh xr2i i sounds like it runs on 2 and it has no revs showing on the clocks i changed the leads the plugs and the coil pack and now i give up any one help at all
Check all the multiplugs in the engine bay for signs of corrosion, mositure etc.
Also check the ECU plug. I expect you've lost the side of the coil that the rev counter derives its signal from.
If you've changed the coil pack it can only really be wiring/connections and/or at worst a faulty ECU
TPM961
Jan 15, 2018 10:50 AM
Andypandy260
Sep 23, 2015 10:28 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
cozzy jeff
Aug 14, 2015 05:46 PM
