boost problem
Old Sep 21, 2006 | 05:07 PM
Maxxeh's Avatar
Maxxeh
Default boost problem
I got it set on the rollers about 2 weeks ago. It was set at 19psi. However, my gearbox went. So i had my gearbox and clutch replaced.
Since i got my car back its only hitting 14 - 15 psi.
HELP!
Old Sep 21, 2006 | 08:21 PM
Escort.Cosworth's Avatar
Escort.Cosworth
Just out of interest what’s the spec of your car?
Old Sep 21, 2006 | 08:59 PM
Maxxeh's Avatar
Maxxeh
stage 1 turbo
bayjoo chip
mahle low comp pistons
kent cam and vernier pulley
pace intercooler
bleed valve
Old Sep 21, 2006 | 09:01 PM
Rick's Avatar
Rick
amal valve is mountes to gbox. That would suggest to me that something round there has changed.
Old Sep 22, 2006 | 12:13 AM
Maxxeh's Avatar
Maxxeh
Wud i need to get the car tuned agen?
Old Sep 23, 2006 | 08:32 PM
HORNETS7's Avatar
HORNETS7
doubt it
most likely earth to gearbox
wires to amal valve
pipes to amal valve
as all these would have been removed with your gearbox
Old Sep 24, 2006 | 01:14 AM
Maxxeh's Avatar
Maxxeh
do i need to adjust the bleed valve myself?
Old Sep 24, 2006 | 02:26 PM
HORNETS7's Avatar
HORNETS7
is it a lockable bleed valve cos if it aint it might be that thats reduced your boost!
bleed valves are nasty pieces of kit anyhow as it could up your boost and blow your engine!
Old Sep 24, 2006 | 05:22 PM
JamboRS's Avatar
JamboRS
focus rs 1672
bleed valves are 100% safe and wont blow your engine up,people tampering with them and turning them thats what blows engines up
Old Sep 24, 2006 | 07:19 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
No problems with bleed valves. Mine has been keeping the same boost level astonishingly well over the last months.
Old Sep 24, 2006 | 08:46 PM
Maxxeh's Avatar
Maxxeh
So what shud i do?
up the boost from the bleed valve? i aint touched it since its been on the rollers.
Old Sep 24, 2006 | 09:42 PM
user 7082039239
Maybe the bleed valve was touched by the guys who replaced the gear box?
Old Sep 24, 2006 | 09:46 PM
addiction's Avatar
addiction
well said
Old Sep 24, 2006 | 09:50 PM
Maxxeh's Avatar
Maxxeh
well im gonna order samco hoses. When i kno its deffffooooooooo not a air leak. Then will it be alrite to turn my bleed valve up until it hits 19psi again?
Old Sep 25, 2006 | 10:29 AM
JamboRS's Avatar
JamboRS
focus rs 1672
Originally Posted by Maxxeh
So what shud i do?
no dont turn it up,you could easily have a leak somewhere which adding more boost wont do any good
take it back and get it set up as what you think is 19 psi on your gauge could quite easily be more in real life,this is exactly what im talkin about when i say that its people that blow engines up,just because boost is down do not touch the bleed valve to compensate,it needs tweakin on the rr
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
