Rev counter problem
Old Sep 15, 2006 | 06:39 AM
snedboy's Avatar
snedboy
Default Rev counter problem
Basically i've bought a Fiesta Turbo with a cosworth engine conversion.Its the black one that was on e-bay.
My problem is that the rev counter doesnt work full stop.The guy i bought it from said that due to different coilpacks between the standard FRST and cossie meant that the counter wouldnt read properly and hense waseant wired up so i am wondering is there a solution to this atall?
Thanks in advance,
Colin.
Old Sep 15, 2006 | 08:35 AM
Adrenaline Junkie's Avatar
Adrenaline Junkie
Id also like to know if there is a way around this.
I've just bought Gracelands E30cosworth, which runs a coilpack, and apparently the wiring is in place for the speedo, but it doesn't work.
I presume its the same problem you're having?
Adam
Old Sep 15, 2006 | 08:37 AM
snedboy's Avatar
snedboy
My speedo works fine just not my rev counter
Old Sep 15, 2006 | 08:46 AM
kjc300's Avatar
kjc300
Default Re: Rev counter problem
Thanks in advance,
Colin.
This would sort it out I reckon!!
https://passionford.com/forum/viewto...light=coilpack
Old Sep 15, 2006 | 09:32 AM
snedboy's Avatar
snedboy
Thanks in advance,
Colin.
Yeah i seen that and was gonna contact him and see if it would but waseant sure what it done really lol.
Old Sep 18, 2006 | 01:13 PM
Adrenaline Junkie
Sorry, that was a typo.. i meant rev counter.. my speedo works just fine aswell
Old Sep 18, 2006 | 02:04 PM
xrchris's Avatar
xrchris
if all else fails you could fit a separate rev counter. take a feed for it from the coil wire in the power and earths and away you go.
Old Sep 18, 2006 | 03:41 PM
Adrenaline Junkie
Can i power my standard BMW rev counter that way?
Also, my SECs monitor reads half on the rev counting department, i'm told this is due to the coilpack conversion, is there anything i can do about that?
If i can, i might have to try and figure out where the wiring for it goes now...
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
